Kneepuck
Flight distance : 275105 ft
The receiver module will not work with the Phantom in any case. The Phantom uses a proprietary encoding for the stream, and it is not compatable with the FatShark receiver. You would need to mount a camera on the Phantom that will talk to the receiver.
As a couple of alternatives, you can get an Nvidia Shield tablet instead of the Hdmi module. The Shield has an Hdmi out port on it that the goggles will plug in to.
A better solution, as far as performance of the fpv, is to forget the FatSharks completely and get something like the Headplay goggles, or for about the same performance on the cheap, a set of VRBox goggles that you insert your device into. The advantage over the FatSharks are many. A bigger screen with a better field of view. Head Tracking, which means that when you tilt your head, it tilts the camera gimbal, when using the Litchi App. Cost, the VRBox setup is about 25 bucks as opposed to the 359.00 for the FatSharks. What I did was, I got the Hdmi module, the FatSharks and the VRBox. Now, if I want to, I can use 2 sets of goggles at the same trime, so my " co-pilot " also has a goggle fpv view. This is a big hit.
