Can you mount the GoPro Hero on the Phantom 1?
3843 6 2015-1-26
swimmer1929
Hi. I am wondering if it is possible to mount the GoPro Hero (the new, budget $130 one) onto the Phantom 1.
Thanks.
2015-1-26
gil
Flight distance : 1379308 ft
It uses the same mounts as all the other GoPro line of cameras so it will fit the camera mount that is included with the Phantom 1.
2015-1-27
raimondopacci.g
Yes we can. I did it. You can install your camera (w/o the back cover to reduce the weight), removing the lower brace (unscrew it). Then, fix the Hero with some hot glue. I fly with no problems and film with same quality of any other Gopro (depends from the settings, obviously)
2015-1-28
MassDrone
Flight distance : 894642 ft
raimondopacci.g Posted at 2015-1-29 01:42
Yes we can. I did it. You can install your camera (w/o the back cover to reduce the weight), removin ...
I also use a GoPro Hero (the $129 version) on my Phantom 1. I did't like the supplied GoPro mount, as my large fingers couldn't hold the nut securely as I turned in the screw. My solution was to use the flat-sided sticky mount that came with the GoPro. Its nut is permanently attached, so all it takes is turning the screw to attach the camera to the drone.
I attached the stick pad to the lower shell just behind the small screw on the front so as not to block access to the screw. The mounting is semi-permanent, and I know that general-aviation pilots use the same mount on their aircraft flying at 120+ knots.
2016-1-12
ericleclair88
raimondopacci.g Posted at 2015-1-28 22:42
Couldn't have said it better my self   You can always make custom parts as well using 3d printing. Like this FPV / OSD Mount.
https://pinshape.com/items/6180- ... antom-fpv-osd-mount
I would rather buy the parts just because I'm not tech genius . . . yet
2016-1-22
RATTYDUDE77
Flight distance : 2917 ft
yes you can the gopro is used a lot with the phantom family....
2016-4-10
fans6d8b674a
Japan
RATTYDUDE77 Posted at 2016-4-10 07:39
Also just go to Youtube and you'll see how tons of people are mounting GoPros on drones. I'm sure it will help you out.
2017-10-21
