AC antennae
kdcox
Flight distance : 1386588 ft
Greetings, i reshelled my banged up p3pro and one of the antennas broke off right at the plastic part that snaps into the leg.  It flies and sends video fine, but i havent done a range test (cuz im scared lol).  Is part of the antenna embedded inside the plastic, or does the plastic simply serve to secure the antenna wire...thanks in advance.
2016-7-31
DJI-Jamie
Flight distance : 112405 ft
Could you provide a picture of the damage?
2016-7-31
kdcox
Yes when I get back home, thank you.  Basically the antenna wire just broke off RIGHT at the plastic part that slides into the leg.
2016-7-31
kdcox
Pic...I tried to solder the wire back, and hot glued the wire.
2016-7-31
DJI-Jamie
kdcox Posted at 2016-8-1 05:59
Yes when I get back home, thank you.  Basically the antenna wire just broke off RIGHT at the plastic ...
Whenever you have time would bee appreciated.
2016-7-31
DJI-H.C
Flight distance : 13602 ft
kdcox Posted at 2016-7-31 23:40
Did it work after you glued it? It if doesn't, you can find spare parts online.
2016-8-1
kdcox
It seems to work fine but I expect the solder joint to fail.  I just didn't know if an important part of the antenna is embedded in the plastic or if the plastic simply serves as an anchor to keep the wire securely in place.  Got a new set coming.
2016-8-1
