Donnie
Flight distance : 3636782 ft
My gains are all set to 100 for Pitch , Roll, Yaw, and Vertical .
My expo is at Throttle .35 Rudder at .25 and Yaw at .35
Check and make sure your yaw is not out of Whack on the exp , if over 50 it will be super sensitive at or near neutral .
When you downgraded did you test fly ? or did you just re load the Latest version ? You may wish to downgrade and test fly to be sure that this may be the problem.
Also on the go app Gimbal Settings / Advanced reset the settings and see if that helps , maybe the aircraft is yawing ever so slightly but the large Camera is making the move seem more drastic ( Guess )
donnie |
