Awful camera signal (everybody need to check this)
12Next >
4046 59 2016-8-3
Insieme Agency
Flight distance : 420449 ft
Hungary
Hello guys,
Its me again!
Soo I had a problem wiht the newest FW, then I downgraded to WM610_FC550_FW_V01.08.01.00.bin (first it starts a realy bad continuous noise and a RED light) the txt. said: Faile, repeat!
- Okey, I done it and for the seconde time it was succesfull!
Than I start to UPGRADE again (HOLY MOTHER OF JESUS ) and it was the same: (first it starts a realy bad continuous noise and a RED light) the txt. said: Faile, repeat!
- Okey, I did it, I inserted the SDcard and It was okey, no upgrading, the txt. file sad: ABORTED, because the NEW FW was upgraded on the Aircraft (I don't understand how because the process doesn't worked and said FAIL before and how was the upgrade done it itself? )
BUT LETS SAY I don't care I have the new FW AGAAAAAAIN, lest try the Aircraft.
So first the same problem I had before: https://www.dropbox.com/sh/v1uuf ... F9yTtxPsRV5tda?dl=0
And now I have a seconde PROBLEM DJI !!!!!!!
This:  https://www.dropbox.com/sh/ceyim ... vsbKW2z-1myLja?dl=0
The video shows the camera signal is realy awful, its unusable! On the SD card the file (captured in 4K 30FPS) is okey, but when I was flying I couldn't see nothing.
PLEASE help me or make a new FW, because I don't have these problems before the NEW FW came out, I'm talkng about this one:  WM610_FC550_FW_V01.09.01.30.bin
SO I have 3 questions:
First: Why I having this GPS SIGNAL OFF all the time?  (Can't be the GPS cable becasue I don't crased with this drone (I hope I won't )
Seconde: Why I had a problem with the FW downgrade and with the update?
Third: Whats the problem with the camera signal? ( I checked the cable what goes in to the iPad and into the RC and it is okey, I will check the manual HD and see if there is someting bad with some of the chanels, but I'm on the AUTO.)
Thanks a lot guys for your answer in the future!!!!!
I appreciate that!
2016-8-3
Insieme Agency
Hungary
Please someone HELP me! :/
2016-8-3
Insieme Agency
Hungary
Someone?
2016-8-3
DJI-Paladin
Flight distance : 2408 ft
Hello Insieme Agency,
1.In the second pic, there are 18 satellites. GPS signal can be influenced by the environment when flying near obstacles or buildings.In the live feed, is the drone in P-GPS mode with some satellites?
2.I‘d suggest you to format the card and re-upgrade with the latest bin file.Then post the hidden log here and I'll take a look
3.Try to clear the app‘s cache and enable hardware decoding option in General settings. Make sure the interference is weak in the environment.
2016-8-3
Insieme Agency
Hungary
DJI-Paladin Posted at 2016-8-4 05:36
1.In the second pic, there are 18 satellites. GPS signal can be influenced by  ...
Thanks for the help!
So I was in P-GPS mode, and I had 19-20 satellites, so its really good to have a week connection. In the video you can see there is NO obstacles near by.
I will format the DS card and I will re-upgrade today.
The hardware decoding is enabled, but where can i clear and what in the app's cache? video cache or the flight routes? I don't want to clear them!
2016-8-4
Insieme Agency
Hungary
GOOD NEWS:
I re-upgraded the FW, so I have the newest one and there was no problem with the upgrading process BUT
BAD NEWS:
I have the same problem! (No GPS signal 4-5 times/flights AND really weak image signal)
I thought maybe I need to do the : Linking Remote Controller process and I made it and STILL have the problem!
So I relay don't understand what can I do with this problem, because I want to solve it!
When I downgraded to 01.08.01.00.bin I don't had weak image problem, SOOOOOOO the conclusion:
THE NEW FW IS DOESN'T WORK PERFECTLY !
What should I do now?
2016-8-4
Donnie
Flight distance : 3636782 ft
Insieme Agency Posted at 2016-8-4 12:31
GOOD NEWS:
I re-upgraded the FW, so I have the newest one and there was no problem with the upgr ...
Make sure that you clear the video Cach on the ipad, also make sure you are runnig no other apps in the backround, check the camera and Gimbal connection  make sure you have no bent pins, also look at the cable between the Aircraft and the Gimbal  ( Black Cable ) , make sure not crimped.
Also try another cable from the I pad to the RC transmitter
Also make sure the Go App image Transmission settings is set to auto , make sure the channels are not getting interference.
I would also Delete and reload the  Go app, this is simple , make sure you have the latest update.
Also try another I pad if you can, the Go app is easy to install and it will help tell where  the problem lays.
You are using an I-PAD correct ?  It looks like one but I want to be sure.
Keep in Mind the GPS will NOT wqork when you are in ATTI mode ( Manual ).  It will only work in GPS mode
Have you ever crashed this  aircraft or camera system?
BELOW IS A SAMPLE  (OLD ) SCREEN SHOT : Can you please list  yours in the same manner, go to the "About " page of the Go app and list all of your current versions on the system please
donnie
2016-8-4
DJI-Jamie
Flight distance : 112405 ft
Here is something you can try as well to ensure that everything is communicating properly. Try resetting the RC using the following button combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
That should ensure that there aren't any issues from the RC side of it.
2016-8-4
DJI-Paladin
Insieme Agency Posted at 2016-8-5 01:31
GOOD NEWS:
If the GPS issue only happen in viewing the records in IOS app, try to update it to the latest 2.8.6 app.
2016-8-4
Insieme Agency
Hungary
DJI-Jamie Posted at 2016-8-4 23:48
Here is something you can try as well to ensure that everything is communicating properly. Try reset ...
I'm done it, but nothing changed!
I pressed the C1, C2 and the shutter button at the same time, right?
2016-8-4
Insieme Agency
Hungary
DJI-Paladin Posted at 2016-8-5 05:06
If the GPS issue only happen in viewing the records in IOS app, try to update it to the latest 2.8 ...
Paladin,
Thanks for your comment.
Here you can see I have that version:
https://www.dropbox.com/s/olj9c5hy3g08tp9/IMG_0641.PNG?dl=0
I wrote down before I don't have this problems, at the WM610_FC550_FW_V01.08.01.00.bin AND I don't have this problem with the WM610_FC550_FW_V01.09.01.10.bin
WHEN I upgraded to WM610_FC550_FW_V01.09.01.30.bin this problems comes out all the time!!!!! In every flight! :/
2016-8-5
Insieme Agency
Hungary
Donnie Posted at 2016-8-4 20:44
Make sure that you clear the video Cach on the ipad, also make sure you are runnig no other apps in ...
Thanks Donnie,
- So I cleared the video catch on the iPad (but I don't understand why this can cause this type of problem), when I'm flying I always shutting down all the apps, so there are no apps in the backround.
- I checked the black label (camera-gimbal AND Aircraft-gimbal) and there are no physical changes.
- I also tried another cable for the iPad Air and the RC, and I still had the problem.
- The Image Transmission Setting are in AUTO, but nowadays I remarked that there are too much Unstable channels !!!
- I use iPad Air and iPhone6
- I don't crashed my drone (and I hope I will not in the future )
- I know that in ATTI mode there are just VPS and NO GPS signal (I'm not a beginner )
-HERE is my FWs on everything:
I will delete the DjiGoApp and I will reinstall! Lets see what happens!
I'm waiting for your answer Donnie and thanks a lot!!!!!!!!
2016-8-5
Insieme Agency
Hungary
And now I have this:
https://www.dropbox.com/s/kn4py2 ... %2009%2042.mp4?dl=0
Interesting right?
2016-8-5
Donnie
Insieme Agency Posted at 2016-8-5 03:38
Thanks Donnie,
- So I cleared the video catch on the iPad (but I don't understand why this can ca ...
The reason clearing the cache sometimes works is because it takes some of the load off the processor, this way the video does not compete for space if it was full.  It is the same thing with making sure the "Hardware Decode " is enabled, takes some of the load off the processor.
You should also try to fly in a different area, drive 10 miles away and see if you still have problems, it may be just interference.
THANKS FOR SENDING ME THE VERSIONS  ABOUT PAGE :  I will  make sure they work
Re- install go app, and see if it improves.
Does the I phone 6 do the EXACT SAME THING ?
You may just need to send this in if we cant figure it out, may have been damaged somehow.
donnie
2016-8-5
Donnie
Insieme Agency Posted at 2016-8-5 05:43
https://www.dropbox.com/s/kn4py2j5r3z8gte/Video%202016.%2008.%2005.%2013%2009 ...
delete and Re- install the Go App
donnie
2016-8-5
Insieme Agency
Hungary
Donnie Posted at 2016-8-5 14:16
donnie
I done it! Now I will check it and write you a message! Thanks Donnie!
2016-8-5
Donnie
Insieme Agency Posted at 2016-8-5 07:21
Ok, I am lighting a candle and saying a prayer !
Ok also , how are you at 2.8.6 on the Go app ?  are you on some sort of Beta Testing App ?  I think you shouold have version 2.8.4 for the I pad .  This is acoording to the latest Release notes, unless I missed something.
donnie
2016-8-5
Donnie
DJI-Paladin Posted at 2016-8-4 22:06
How can he have version 2.8.6 for  Go app ?
Could he have the wrong Beta version   Is it different in Hungary ?
donnie
2016-8-5
Donnie
Ok, are you flying an Inspire 1 with X3 camera OR x5 ?  ?  You must have the x5 pro ?
This is critical, what camera do you fly with ?
You are flying with the PRO firmware, this is fine if you have the x5  pro but not any other system
1.9.1. 10   INSPIRE PRO
YOU NEED TO TRIPLE CHECK WHAT FIRMWARE YOU HAVE , IF YOU FLY WITH A INSPIRE 1 PRO THEN YOU MUST LOAD THAT FIRMWARE IF YOU HAVE THE
INSPIRE PRO WITH THE X -5RAW, THEN YOU MUST USE THAT FIRMWARE.
THESE ARE LOACATED VERY CLOSE TO ONE ANOTHER AND ON THE SAME  PAGE.
I THINK THIS IS WHERE THE PROBLEM IS
still confused on version 2.8.6 for the go app .................
donnie
donnie  .
2016-8-5
Insieme Agency
Hungary
Donnie Posted at 2016-8-5 16:49
Ok, are you flying an Inspire 1 with X3 camera ?  You must have the x5 pro or raw correct ?
Hello Donnie,
I have an Inspire 1 Pro, so a Zenmuse X5 camera on it!
I have the PRO FW: Inspire 1 Pro Firmware v1.9.1.30
2016-8-5
Donnie
Insieme Agency Posted at 2016-8-5 10:13
Hello Donnie,
How is the Go app at 2.8.6 ?
Sorry I have been thinking about your situation for the last hour, I thought you may have loaded the raw FW on you x5 pro .
You dont think you could have put the raw fw on the  aircraft do you ?  That would cause similar problems ....
donnie
2016-8-5
Insieme Agency
Hungary
Donnie Posted at 2016-8-5 17:15
Thanks Donnie, you are a really good lad!
I have the newest GoApp update too, you saw that on the picture. I reInstalled it, but I don't tryded yet. But I will today, but the weather was not good here!
I don't put the RAW FW on My SD card, never!!!!
2016-8-5
Donnie
Insieme Agency Posted at 2016-8-5 10:17
I have the newest GoApp update too, you saw that on th ...
Ok, get back with me  when you can ,  See if the go app is now at 2.8.4 that is what it should be for the I pad.
Cheers from the USA
donnie
2016-8-5
Insieme Agency
Hungary
Donnie Posted at 2016-8-5 17:19
Ok, get back with me  when you can ,  See if the go app is now at 2.8.4 that is what it should be  ...
I have the same at the About version settings:
App: Version 2.8.6
Cheers from Hungary!
2016-8-5
Insieme Agency
Hungary
Paladin,
this is how the No GPS Singal problem will be solved?
I'm just kidding, BUT get back to the task: SO now I can't reView some of my flights, those ones where were No GPS Signals.
I have the NEWEST App: 2.8.6.
2016-8-5
DJI-Jamie
Insieme Agency Posted at 2016-8-5 15:59
I pressed the C1, C2 and the shutter button at the same time,  ...
yes you would hold all 3 for a few seconds. In addition, you would want to keep holding those buttons when you power the RC back on.
2016-8-5
Insieme Agency
Hungary
DJI-Jamie Posted at 2016-8-5 18:55
yes you would hold all 3 for a few seconds. In addition, you would want to keep holding those butt ...
So I hold the 3 buttons when the RC is on and than I power off, than again holding all the 3 buttons and power ON at the same time?
Should I need to see or hear something?
2016-8-5
DJI-Jamie
Insieme Agency Posted at 2016-8-6 00:57
So I hold the 3 buttons when the RC is on and than I power off, than again holding all the 3 button ...
When you hold the buttons down, you should hear a quick chirp from the RC. Keep holding the buttons when you turn the RC off and on again.
2016-8-5
Insieme Agency
Hungary
DJI-Jamie Posted at 2016-8-5 19:46
When you hold the buttons down, you should hear a quick chirp from the RC. Keep holding the button ...
I don't here nothing!
2016-8-5
Insieme Agency
Hungary
Jamie,
I don't get nothing. Not a voice, maybe I can say I just saw when I folded the 3 buttons and turned the RC before the red there was a green light.
Nothing more!
2016-8-5
Insieme Agency
Hungary
I tried with the iPhone6 and I had the same camera problem.
Tomorrow I will try to fly with the drone and see if there is a awful image signal on my screen!
I hope the best!
2016-8-5
DJI-Jamie
Insieme Agency Posted at 2016-8-6 04:00
Jamie,
I don't get nothing. Not a voice, maybe I can say I just saw when I folded the 3 buttons  ...
I'm sorry, I do not quite understand what you mean by the LED indicators you're receiving. Could you please clarify?
2016-8-5
Insieme Agency
Hungary
DJI-Jamie Posted at 2016-8-5 22:21
I'm sorry, I do not quite understand what you mean by the LED indicators you're receiving. Could y ...
I sad when I turned on the RC and it showes RED if the Aircraft is not connected, but when I pushed the 3 buttons and at the same time I turned on the RC it was first green and than red. (THE AIRCRAFT was not turned on)
2016-8-5
DJI-Jamie
Insieme Agency Posted at 2016-8-6 05:02
I sad when I turned on the RC and it showes RED if the Aircraft is not connected, but when I pushe ...
That seems about right. Did you rebind the RC to the aircraft as well?
2016-8-5
Insieme Agency
Hungary
DJI-Jamie Posted at 2016-8-6 00:43
No, but I will.
So that means I need to do the process again ? (3 buttons combination + rebind)
2016-8-5
Insieme Agency
Hungary
Jamie, I have the hidden logs but I can't open it up.
I have this: .fseventsd  AND .Trashes AND MISC
Which one do you need?
2016-8-5
Insieme Agency
Hungary
I'm done with the process (3 button combinations and Linking Remote Controller ) but I have the same problem. The picture what I can see on the iPad is still having the same problem.
2016-8-5
Insieme Agency
Hungary
Jamie,
I done everything and indoor you can see I have the same problem:
https://www.dropbox.com/s/l2arih ... %2055%2016.mov?dl=0
If I go outside its just getting worse....
2016-8-6
Insieme Agency
Hungary
Someone ?!?
2016-8-6
Insieme Agency
Hungary
Sorry guys, but I still have the problem!!!!
2016-8-7
12Next >
