Weak Image Transmission
Michael M
Flight distance : 1984898 ft
I'm getting weak transmission signal all of a sudden, even when the p3a is right above me, a couple of meters away.
All firmware is latest and I know how to properly position my antennas and all. My transmission is set to auto and it's always worked fine.
Is anybody else experiencing this and does anyone have any suggestions?
2016-8-3
Geebax
Just a small point, even pointing the antennas on your RC unit will not always solve a signal loss when the aircraft is directly above you, because the antennas in the aircraft are still pointing down verically and that is the worst position.
2016-8-3
Michael M
Geebax Posted at 2016-8-4 07:17
Just a small point, even pointing the antennas on your RC unit will not always solve a signal loss w ...
ok maybe not directly above me. I mean near, hovering at a 45degree angle from me.
Im not new at this and I know how to position my antennas. This is a new problem that I am experiencing and ive changed nothing with my flying.
2016-8-3
Geebax
Michael M Posted at 2016-8-4 10:46
Im not new at  ...
Sure, I understand. The reason I mentioned it is because every time there is a loss of signal incident the video tutorial on antenna positioning is trotted out. But few people understand that when the aircraft is directly above you, you can re-adjust the antenna positioning on the RC unit as much as you like, the problem is then with the antennas on the aircraft which cannot be moved.
2016-8-3
DJI-Paladin
Flight distance : 2408 ft
Hello Michael, so now will this issue come up every time you fly and everywhere? Have you tried to use custom channel and lower transmission quality?
2016-8-3
DrawsWithLight.
Flight distance : 2136716 ft
Try disconnecting and reconnecting cables to gimbal, worked for me and a few others here
2016-8-4
Michael M
DJI-Paladin Posted at 2016-8-4 14:56
Hello Michael, so now will this issue come up every time you fly and everywhere? Have you tried to u ...
Well it's a new issue. Dji emailed me some tips to try so I will try them out, I am leaving for vacation so I will be in a new area
2016-8-4
DJI-Ken
Flight distance : 1515312 ft
Michael M Posted at 2016-8-5 01:15
Well it's a new issue. Dji emailed me some tips to try so I will try them out, I am leaving for va ...
Let us know in the new location how it works.
If you are doing everything exactly the same and in the exact same area and all of a sudden you are experiencing it then it can be either something has just been installed there causing interference or something happened to the RC or A/C to cause it. If you can only get a few meters something is wrong.
2016-8-4
imagesbyjas
Flight distance : 286198 ft
DrawsWithLight. Posted at 2016-8-4 16:04
I'll second this..  While my "Weak Video Signal" messages were still at a minor distance, the aircraft was plainly in sight...  I unplugged and plugged those gimbal cables yesterday and didn't have any video issues until I was well out in distance... Something to it, it seems...
Had a different issue and about to post, but didn't lose video signal ...
2016-8-4
vonHoo
Sweden
imagesbyjas Posted at 2016-8-4 20:19
I'll second this..  While my "Weak Video Signal" messages were still at a minor distance, the airc ...
Hi,
I'm experiencing this problem as well, do you have any video tutorial on how disconnect which cables?
Thanks!
2016-8-5
vonHoo
Sweden
DJI-Ken Posted at 2016-8-4 20:01
If you are doing everything exactly the same and in  ...
Hi,
I'm experiencing the same problem. Could you please send me the same mail with description how to solve the problem?
Thanks!
2016-8-5
DJI-Ken
vonHoo Posted at 2016-8-5 22:25
Hi,
I'm experiencing the same problem. Could you please send me the same mail with description ho ...
Can you please explain in detail what your issue is with weak transmission.
What aircraft do you have?
What are are you flying in, is it out in the open or in a congested area?
Are your antennas properly orientated, watch the video and see if it helps.
If you have a Adv or Pro you can go into HD settings and choose custom and pick the strongest signal and lower the bitrate.
Have you made sure the cables are firmly seated?
What device are you using?
2016-8-5
imagesbyjas
vonHoo Posted at 2016-8-5 22:24
Hi,
I'm experiencing this problem as well, do you have any video tutorial on how disconnect whic ...
Here's one video.. There are a few more.  The hardest part is to get the anti-drop pins out.  This is one method.  Just be "gentle" as you can when working with the gimbal.. It's not a part you want to rough house with.  Once the gimbal is able to be lowered from the aircraft, you will see two cables.  Two of the ends you can't get to, but two of the ends are visible.  Carefully unclip and remove the cable and then just securely slide it back into place.  Again, just take it slow and easy.  You have extra pins (they came with the drone), so if you want to go at it a different way, cut the pins (strong wire cutters?) and replace with some you got from what came..  The bumpers are easy to get out and back in..
2016-8-5
WolvesSi
I had exactly the same problem. The video transmission is sent from the camera via the single black cable which I believe comes from the left of the gimbal as you look head on at the drone, upon inspection i found the UFL female connector had come away from the board. Apparently due to dry solder. You can get to this cable, but it can be a little tricky, don't be too rough on them.
Good luck.
2016-8-5
Michael M
DJI-Ken Posted at 2016-8-4 11:01
I followed djis suggestions to re ibstall the go app abd then re link the aircraft abd on my new location it worked i think. I was not watching the screen but i think it worked outm ill ket you know if it happebs again abd u advise everyone to try these steps
2016-8-5
Michael M
Sorry for the typos I'm sending this from my phone
2016-8-5
DJI-Ken
Michael M Posted at 2016-8-6 08:15
I followed djis suggestions to re ibstall the go app abd then re link the aircraft abd on my new l ...
That's great to hear.
2016-8-5
DJI-Ken
No problem, I had a mishap replying with speech to text and it said I called this guy "Babe". I didn't even notice it until he replied back to me
2016-8-5
vonHoo
Sweden
DJI-Ken Posted at 2016-8-5 16:42
What aircraft do you h ...
Aircraft: Standard
Phone: Iphones 6S
Area: Works fine in open area, in congested area (cities) the video link drops after 5 meters
Antennas: Yes, I'm very familiar with the video you linked
Cables: Yes
Is it not possible to change the signal setting on the standard?
2016-8-6
Michael M
DJI-Ken Posted at 2016-8-5 17:52
No problem, I had a mishap replying with speech to text and it said I called this guy "Babe". I di ...
Haha that must have been fun
t seams auto correct is disabled when typing in the dji forum. Everywhere else it works.
2016-8-6
AG0N-Gary
Flight distance : 700846 ft
DJI-Ken Posted at 2016-8-5 19:52
Now THAT'S funny, Ken!
2016-8-6
DJI-Ken
vonHoo Posted at 2016-8-6 18:59
Aircraft: Standard
Phone: Iphones 6S
Area: Works fine in open area, in congested area (cities) the ...
You cannot change the setting on the Standard. If you lose signal after 5m in a congested areathen there is something wrong. Can you please post a video.
2016-8-6
DJI-Ken
Michael M Posted at 2016-8-7 02:11
t seams auto correct is disabled when typing in the dji fo ...
Yes, it was quite embarrassing. Sometimes when I'm in a hurry I don't check after hitting enter. Need to stop doing that.
2016-8-6
DJI-Ken
AG0N-Gary Posted at 2016-8-7 02:32
Yes it was
2016-8-6
vonHoo
Sweden
DJI-Ken Posted at 2016-8-7 05:31
You cannot change the setting on the Standard. If you lose signal after 5m in a congested areathen ...
Hi,
Yes I could, but I don't see what that would help as the video is fine on the SD card. The problem is that I cant see what I'm actually filming after 5 meters. And this happens only in congested areas.
Do you still want me to upload a video? Where can I upload it?
2016-8-8
DJI-Ken
vonHoo Posted at 2016-8-9 01:26
Hi,
Yes I could, but I don't see what that would help as the video is fine on the SD card. The p ...
You cannot change the video transmission signal on the Standard.
Even if in a congested area it should work way further than you are getting.
What is the congested area?
Since you have an recommended device, have proper antenna orientation you should have 5m limit then lose video.
I would contact support and see about sending the aircraft in for repair.
2016-8-8
imagesbyjas
DJI-Ken Posted at 2016-8-7 11:33
Yes, it was quite embarrassing. Sometimes when I'm in a hurry I don't check after hitting enter. N ...
We've all been there Ken (with auto-correct).  A client sent me a text with more than a slight "off color" text string in it (auto correct and dictation so the worst of both worlds).  Thank goodness it was a private message and not a post on FB!!  :-)
2016-8-8
