Inspire 1 Central Screw Lubricant
1393 7 2016-8-4
delcodrones
Flight distance : 440367 ft
Hello,
I have just returned from some travel with my inspire 1 where i was flying above salt water and sand. I got to thinking about the maintenance after flights in these conditions. Can anyone recommend a lubricant for the central screw? Also what is the best process for getting ride of the sand particles that may end up in the inspire 1. Thank you for your recommendations
2016-8-4
R&L Aerial
Flight distance : 298100 ft
I use canned air to blow my inspire out and a drop of mineral out on the screw.
2016-8-4
Farnk666
Flight distance : 1711394 ft
Most people I've heard doing this use a very small burst of 'Tri-Flow' after a blow out with compressed air.
2016-8-4
delcodrones
R&L Aerial  Posted at 2016-8-5 05:39
That's what i was thinking i was worried that spraying to close could harm the rubber since that stuff get very cold. So i'll just do it from a distance. Thanks for the suggestion
2016-8-4
delcodrones
Farnk666 Posted at 2016-8-5 06:52
Most people I've heard doing this use a very small burst of 'Tri-Flow' after a blow out with compres ...
I have some Lub-It All which is similar to Tri Flow I'll just apply to a q tip. Thanks again
2016-8-4
aknauer
Flight distance : 793041 ft
New Zealand
I use copressed air to clean and CorrosionX for lubrication and corrosion prevention.
Works really well on all types of equipment
2016-8-4
GabeZ
Flight distance : 768448 ft
Last I checked, the maintenance and service manual said to use WD-40.
2016-8-4
delcodrones
GabeZ Posted at 2016-8-5 11:17
Going to check that thanks
2016-8-5
