Phantom 3 Advanced question
1492 19 2016-8-4
Jlcdrummer
Hey guys I've been doing some research on the P3A and I've noticed especially on Amazon that some P3As say only 1080p camera instead of the 2.7k camera. Were earlier models of the P3A only 1080p instead of the advertised 2.7k? I want to make sure when I order, I'm getting the correct 2.7k model. Unless they are just incorrect in their description and all P3As have the 2.7k camera included.
2016-8-4
DJI-Ken
Flight distance : 1515312 ft
The P3A will do 2.7k.   2.7K: 2704 x1520p 24/25/30 (29.97)
Here's all the specs    http://www.dji.com/product/phantom-3-adv/info#specs
2016-8-4
Jlcdrummer
DJI-Ken Posted at 2016-8-4 16:52
Here's all the specs    http://www.dji.co ...
Great thank you so much! I was just noticing some Amazon P3As we're only advertising it as 1080p and not 2.7k
2016-8-4
labroides
Flight distance : 9991457 ft
Jlcdrummer@hotm Posted at 2016-8-5 07:59
Great thank you so much! I was just noticing some Amazon P3As we're only advertising it as 1080p a ...
All P3As has been able to shoot 2.7K video ever since Firmware 1.4.
You are seeing ads using the descriptive text from before that time.
2016-8-4
DJI-Ken
Jlcdrummer@hotm Posted at 2016-8-5 05:59
No problem at all, you can also order from DJI.com too.
2016-8-4
lkmcd
2016-9-5
AustrianOak82
I just asked this same question to an online chat representative and her response was, "That is just an aproximately.Actually the range in the shoot in 1080p is depends in he intereference in the location." I was confused at the range and resolution on the box and in the manual.
She is getting with the "Developer Department" to get me an answer. I am guessing I am good to go, the box is wrong or something?
2016-11-1
Kneepuck
Flight distance : 275105 ft
AustrianOak82 Posted at 2016-11-1 17:31
I just asked this same question to an online chat representative and her response was, "That is just ...
lol,  welcome to the dji family.  you will generally get much more useful information here on the forum.  you are good to go.
2016-11-1
Phantomski
Flight distance : 14869882 ft
amazon specs stink, just like ebay and many others..... people do not put the right stuff in their advertisement....
2016-11-1
AustrianOak82
Phantomski Posted at 2016-11-2 11:51
amazon specs stink, just like ebay and many others..... people do not put the right stuff in their a ...
I got this directly from DJI and the webpage had the right specs, it's the box that doesn't. I am still confused.
2016-11-3
Geebax
AustrianOak82 Posted at 2016-11-2 08:31
Yes, the box is wrong, all P3 Advanced aircraft can shoot in 2.7K. The specs posted on the DJI web site are also correct. The chat people are giving you wrong information, happens quite often actually.
2016-11-3
DJI-Jamie
Flight distance : 112405 ft
AustrianOak82 Posted at 2016-11-4 09:03
I got this directly from DJI and the webpage had the right specs, it's the box that doesn't. I am  ...
The earlier versions of the P3A used to only shoot in 1080P. A firmware update allowed the series to record in 2.7K. Depending on where you bought it and what motors you have, you most likely got an older version that still had the older 1080P advertisement on it.
2016-11-3
AustrianOak82
DJI-Jamie Posted at 2016-11-4 01:13
The earlier versions of the P3A used to only shoot in 1080P. A firmware update allowed the series  ...
Okay, so what about the range being listed as 1+ versus 3+? I am only asking because the range on this seems to be about the same as my P3S. I haven't been able to go farther than about 3/4 of a mile in several locations. Yes, I am pointing the antennas correctly.
2016-11-13
Labroides
AustrianOak82 Posted at 2016-11-14 10:17
Okay, so what about the range being listed as 1+ versus 3+? I am only asking because the range on t ...
Are any of those several locations good low interference areas?
The Advanced will easily fly several miles out away from interference.
2016-11-13
AustrianOak82
Labroides Posted at 2016-11-13 18:25
The Advanced will easily fly severa ...
I live out in the country, so aside from some general patches of trees and power lines, yeah.
2016-11-13
Labroides
If your Advanced will only go as far as a Standard, something's not right.
The Lightbridge Advanced has a range much greater than the wifi Standard and easily goes much further.
How's your antenna orientation?
2016-11-13
AustrianOak82
Labroides Posted at 2016-11-13 22:01
The Lightbridge Advance ...
Well, like I said, "Yes, I am pointing the antennas correctly."
2016-11-13
Geebax
'I just asked this same question to an online chat representative and her response was, "That is just an aproximately.Actually the range in the shoot in 1080p is depends in he intereference in the location."
It is so sad that someone who is charged with dealing with customers can make such a stupid, non-sensical answer as that.
2016-11-13
DJI-Jamie
AustrianOak82 Posted at 2016-11-14 10:51
Just a few things to try, if you have not already. I would recommend resetting the RC by using the following button combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and relink the remote.
Once you relink the RC to the aircraft, that should ensure a more stable reception.
2016-11-17
Kneepuck
AustrianOak82 Posted at 2016-11-13 22:03
I have gotten 3 miles out of my Advanced and I live in the mountains.  You may want to have it checked out.
2016-11-17
