techmyjustin
Flight distance : 191896 ft
Hi all, I will be filming some waterskiers tonight at a private pond, and I will be flying in Sport mode for a lot of the time just to keep up with the boat going @35 MPH. I'll take some other angles too, like some passes that won't require the high speeds. I'll keep in mind to angle the camera down far enough that the props aren't getting in the frame from higher speeds, higher tilt.
Should I be aware of any overheating issues? I plan to use my 3 batteries, can Sport mode flying cause the drone to get too hot, that damage may occur or a system could fail?
Should I let the body cool down in between batteries, does it matter?
Thanks for any ideas, I'm just trying to prepare and I would really like my Phantom 4 to not have any problems and fall in the water
