Hi , I tested yesterday with the latest app , the rc is in full bar even 200m away , it is really strange ... How can see the signal strength by percentage ?
Don't think there's a way to see it in the form of a %, just signal bar. Sometimes relinking the drone to the RC can fix things, because it may select a different frequency within a range.
I opened up the controller and pushing those anthena cnnectors harder and use some hot glue to hold the position , guess what I am able to fly 700km with stock anthena
Sometimes I'm thinking just maybe this is why some people are having issues with range (no all) that the parts are not connected correctly when made. So you're saying these cables seemed loose to you before you did this fix?
wmcvey Posted at 2016-8-25 04:55
Sometimes I'm thinking just maybe this is why some people are having issues with range (no all) tha ...
I think that persons case is an isolated event.
If you are experiencing short range since you are in the US call 818-25-0789 and start a ticket and send it in for evaluation.
I think either the solder cracks or it loosens the connections with all the vibration the unit gets. That's why they always get worse over time. I used to fly 2km and now have issues with 200m, and its sporadic. Sometimes 500m but not so much lately. Use to fly as long as it had line of sight, now I can see it crapping out. Flew great till over 120 flights, now like crap. Too much vibrations on the board.
