1flyer
Flight distance : 266378 ft
Well all that has tested ok. So going from my experience with these gimbals and this problem I would concentrate on HDMI cable - This is part 35 for the BMPCC, or even the PCBA Board part 33. I gave these part numbers so you can have a reference to look up to see what parts I mean if you have not yet. I have in cases needed to replace both to fix my problems. The cable can get weak over time and even be an intermittent issue depending on the position it stays in after connecting it to the camera. And, plus with the slight delay from the Air Unit to the Ground Station, chasing a bad cable connection is frustrating. As far as the PCBA Board going bad for me, I have never been able to get an answer to why it does or what I may have done to cause it to fail but they do and I have replaced a few of these as well over the years as well.
I wish I was able to give you a direct path to shoot for but hopefully it's a simple bad cable issue or DJI has a "this is what it is" answer for ya. |
