Indoor ambient
12Next >
2559 42 2016-8-7
e.gargiulo
Flight distance : 5000 ft
Hi. I would fly with phantom 4 in indoor ambient, in a church. Which settings should do I to get the most of the phantom control? Thank
2016-8-7
PhanFran
Flight distance : 4804163 ft
You need to change nothing but you will have to be VERY careful as you will be flying in ATTI-mode and that's a lot more difficult than GPS-mode.
Can't say more because I NEVER fly indoors and I don't think the phantom is designed for indoor-flying really.
2016-8-7
RedHotPoker
Flight distance : 165105 ft
Actually, it's quite surprising how many satellites do connect up to my Phantom 3 Pro', while still indoors.
It really depends a lot on things like windows, basic construction, area or location, and other stuff.
RedHotPoker
2016-8-7
Cetaman
Flight distance : 2528264 ft
Aloha gargiulo,
     As RedHot says, sometimes GPS does work indoors.  That has happened to me.  But as PhanFran says you have to expect to be flying in ATTI-mode and he is right, it is more difficult.
     However, you have an ace up your sleeve because you are flying a Phantom 4.  The Phantom 4 has double IMU systems and a Vision Positioning System (10 meter range, not 3 meter like the P3) that is designed to make flying indoors much easier.  Together they should handle your needs indoors.  But, see if you can get in some practice before the event.
     There are a couple videos on the transition indoors / outdoors with the P4.  You might want to look them up before your practice.  You may just keep it in P mode for both but you need to confirm that.
Aloha and Drone On!
2016-8-7
mochorm
Flight distance : 940148 ft
Are you taking stills, video or both?
Lighting can be a big challenge in churches! If you have a mix of lighting you may want to adjust your White Balance to match your source lighting.
Here is a thread that has some tutorials Photography
2016-8-7
e.gargiulo
thanks to all
2016-8-8
mjlstudios
Flight distance : 1540131 ft
Any flights below 6 feet should be accomplished by hand holding the Phantom if at all possible. Video while hand hold will still be smooth due to the gimble.
2016-8-8
e.gargiulo
hi mjlstudios thanks
2016-8-8
e.gargiulo
so is it difficult indoor flying?
2016-8-8
Moshe.mmm
Flight distance : 1320098 ft
Israel
I would definitely putbon propellers guard.  That is the most important thing when you fly indoors in order to be safe that the propellers would not get hit and of course the p4 would not fall on someone..
2016-8-8
e.gargiulo
thanks. other tips and directions to the phantom 4 indoor?
2016-8-8
nigelbrinkmann
Flight distance : 586391 ft
e.gargiulo@soge Posted at 2016-8-9 04:23
Hi, I've flown mine inside many times in p mode, through door ways, up stairs, out open windows etc, If you are competent pilot you can turn obstacle sensing of then it will go through doorways etc, with the obstacle sensing on the p4 stops quite often inside which is normal operation.
Just remember everyone's safety if flying near or around people. just watch out for loose ojects when flying inside that can get caught up in the props!
2016-8-9
e.gargiulo
nigelbrinkmann
thank
2016-8-9
e.gargiulo
Hi Cetaman
<There are a couple videos on the transition indoors / outdoors with the P4.>   where are these videos? Thanks
2016-8-9
sahtemeyil
Flight distance : 946407 ft
Turkey
In case of RC signal lost , set the mode to Hover , NOT to RTH
2016-8-10
e.gargiulo
hi sahtemeyil. Thanks. Why?
2016-8-10
DJI-Ken
DJI Team
Flight distance : 1515312 ft
It's very easy flying indoors, if it's close quarters than you should get prop guards and you will get a lot of buffeting from the air if your close to the walls, close quarters, or AC vent.
And set RTH to hover.
If you have good GPS you can leave it in P mode. If flying under 30ft then the VPS will help to hold horizontal position.
2016-8-10
RedHotPoker
e.gargiulo@soge Posted at 2016-8-10 09:24
Why, is because when you use RTH you set a ceiling height, for it to ascend, to pass over any near by obstructions.
Flying indoors, if an unlikely incident ever did happen, and you lost control, it could try to return home, but first it will fly straight up, into the ceiling.
You can set it to hover, or a safe RTH height of 1m. ;-)
RedHotPoker
2016-8-10
e.gargiulo
thank ken and RedHotPoker
2016-8-10
sahtemeyil
Turkey
That's why ⬆️
2016-8-11
e.gargiulo
ok thank
2016-8-11
Swedrone
Flight distance : 15419022 ft
Sweden
Easy to fly indoors. I did it in germany isnide an abanoned factory. You can walk under it to better see the distance to the walls (43 sec in to the vid).
2016-8-11
RedHotPoker
Using common sense, and control of the Go app parameters, can help you return to fly another day. ;-)
RedHotPoker
2016-8-11
DJI-Ken
DJI Team
No problem at all. Get the prop guards for sure because one little bump from 20ft will bring your aircraft down and probably cost quite a lot for repair. The prop guards are the best insurance  you can have for indoor or close quarter flight.
2016-8-11
RedHotPoker
Close quarters? The prop gaurds make the drone significanly larger... Ha
Seems counter productive, in my obscure way of thinking. ;-)
School me. Record Video in a china shop. No Bull!! Haha
RedHotPoker
2016-8-11
DJI-Ken
DJI Team
RedHotPoker Posted at 2016-8-12 00:48
Seems counter productive,  ...
I meant close quarters, not flyng in a closet
Close quarters if you need to fly next to a wall or close to objects is what I meant.
2016-8-11
RedHotPoker
Yeah, I know, but in a church, there are often valuable art, stained glass, other treasured antiquities.
Best to be very careful, & Not be bumping around, is all I meant. ;-)
RedHotPoker
2016-8-11
DJI-Ken
DJI Team
RedHotPoker Posted at 2016-8-12 00:58
Yeah, I know, but in a church, there are often valuable art, stained glass, other treasured antiquit ...
Ya, that's for sure. Hopefully he's a great pilot and may make money instead of having to pay out
2016-8-11
RedHotPoker
Cool if all goes as planned. Post the video... Ha
RedHotPoker
2016-8-11
e.gargiulo
thanks.. thanks
2016-8-12
e.gargiulo
soon I publish the video but it is only a draft   T H A N K S
2016-8-12
e.gargiulo
2016-8-12
RedHotPoker
Wow, wait a minute, a cathedral. Hahaha
Thought you said church? ;-)
Not a football field sized environment. Ha
Anyway, nicely flown, and decently recorded. Just what I wanted to see.
Nice music too, very soothing to my soul.
RedHotPoker
2016-8-12
DJI-Ken
DJI Team
WOW, very nice, great piloting and looks like the P4 worked great.
2016-8-12
Vinniez
Flight distance : 2106204 ft
Indonesia
superb..... is it difficult to fly indoor ?
2016-8-12
DJI-Ken
DJI Team
Vinniez Posted at 2016-8-13 02:01
It's fairly easy if the VPS is able to recognize the floor as the aircraft will hold position. If not than it's still rather easy if you know how to fly in ATTI mode.
You have to watch out for air buffeting around in confined areas.
Having prop guards make it much easier in case you bump a wall.
2016-8-12
Vinniez
Indonesia
DJI-Ken Posted at 2016-8-13 02:13
It's fairly easy if the VPS is able to recognize the floor as the aircraft will hold position. If  ...
thanks ken ...
2016-8-12
e.gargiulo
thanks .......
2016-8-12
DJI-Ken
DJI Team
No problem, The P4 and P3 VPS works great indoors, you just have to know it's limitations.
2016-8-12
e.gargiulo
Hi RedHotPoker. <decently recorded> What do you want to mean? What does it mean <recorded>? Why <decently>. Thanks
2016-8-12
12Next >
