mochorm
Flight distance : 940148 ft
If your in the line of sight of one of the cell towers radiators your Xcopter will still be impacted even if you are a couple hundred meters away!
I did more testing yesterday with various height towers and once your in front of the actual radiator your signal will be impaired or gone completely. Of course the closer you are the easier it is to loose total signal!! The beam from the radiators is quite narrow so it's relatively easy to avoid it if you know they are present. Once your bird is past the beam it's doesn't seem to have an impact on the over all range you achieve. In one test I would loose complete signal at 30m altitude and 200 m out. If I flew 10m higher or lower the bird would continue and I was out 3.6km with a decent signal.
It's a fact guys!. |
