Mark Guille
Flight distance : 2031818 ft
Jersey
Mikey.C Posted at 2017-1-17 23:11
I do the IMU and compass cal at home on a level surface before every flight. i also cal the compass on location. i have received a new bird after 40 weeks of being away at DJI Europe ( Thanks) through my vender who i purchased the pro with in the first place.
Hi Mikey,
I think you your problem may be from overdoing the calibration. Many people are unsure when to perform the compass calibration so they do it every flight, "to be on the safe side". DON'T. Once you have good cal, leave it. Part of your pre-flight checks should be to check your sensor readings, if you compass mod value is between 1400-1600, you are good to go. The DJI app will let you know if the compass need calibrating. |
