Just installed 1345T props...
850 3 2016-8-13
jim
Flight distance : 491811 ft
I finally removed the 1345S props just for preventative maintenance and replaced them with 1345T's  No flights yet, the CW (Black) props are both a bit loose when they are attached. The locks are tight but the props wiggle a bit, the CCW props do not. Is this normal? Anyone else have this?
2016-8-13
RichJ53
Flight distance : 1837356 ft
jim
This is normal and not to worry
Rich
2016-8-13
jim
RichJ53 Posted at 2016-8-13 11:58
jim
Thanks, although especially since they specifically state that is there is movement to replace them, it's a bit sketchy.
2016-8-16
RichJ53
jim@mauchly.net Posted at 2016-8-16 11:54
Thanks, although especially since they specifically state that is there is movement to replace the ...
jim,
there has been some other posts on this subject and a slight amount of play is normal. If they are loose in the hub mount then, this is something to look into. check out this thread for other information
Link
http://forum.dji.com/thread-53832-1-1.html
Rich
2016-8-17
