Please examine. Wind Gust?
1357 17 2016-8-13
caranod
went out at sunset yesterday and saw a storm on the horizon.  Thought I had time to try the POI feature and then at 10 seconds in, I saw this....  could this have been a wind gust, or something else entirely?  10 seconds into video.
2016-8-13
Heebus
its listed as private, I am unable to watch it
2016-8-13
hallmark007
Flight distance : 9827923 ft
Just saw a black hole at 10 sec
2016-8-13
caranod
My bad. Check it now.
2016-8-13
Heebus
I dont kno that that was wind, it looked like the camera moving, not the drone, but thats just my opinion, uploading your logs @ heathydrones might give more insite
2016-8-13
KM5RG-Robert
Flight distance : 2075213 ft
I've had that a few times. Seems the gimbal either shuts off (overload maybe) or simply is overpowered. I was thinking of posting the same question. It does seem to be wind load related. The first time it happened was the first flight after installing a tulip-style lens hood. Took it off after landing. Has occurred once or twice again on other days without anything added to the lens. Each time it was a windy flight. Will await a reply from DJI.
2016-8-13
caranod
Looks like I had a compas error just before.  not sure if thats helpful or just adds more questions though.
2016-8-13
hallmark007
That's the camera moving,why?
2016-8-13
jwt873
Flight distance : 6754350 ft
You need to post the flight long on Healthy Drones https://healthydrones.com/ or Phantom Help.com http://www.phantomhelp.com/LogViewer/Upload/
You'll be able obtain a lot more information about the flight.
2016-8-13
jcostello182
Flight distance : 1861490 ft
jwt873@gmail.co Posted at 2016-8-13 21:14
You need to post the flight long on Healthy Drones https://healthydrones.com/ or Phantom Help.com ht ...
Looks like gimble to me mate
2016-8-13
Mabou2
Flight distance : 811257 ft
Gimbal.  U can see it hitting its limit on the move.  Send it in for repair
2016-8-13
caranod
It's a new gimbal assembly not even 4 flights old. And another person already states they have similar issue in high wind.  So is this an isolated incident, a common occurrence, or should i have it replaced.
2016-8-13
caranod
Also mechanically speaking, how would it be possible for the camera that is level and pointed in a downward direction, to suddenly be pointing to the left with the horizon vertical and not have the aircraft landing supports in the way? The only way I see it, is if the entire aircraft began to flip over to the right.
As I began a poi rotation turning counter clockwise (aircraft moving to its right) I bevieve I hit a strong wind gust.
I did upload the log to healthy drone but I found no other information there to explain what happened.
2016-8-13
gsxr07boy
It's not wind 100% sure about that you could fly it in 45mph wind gusts and you will never see that happen.  What it is is a gimbal glitch/Melfunction try to reset the p4 with DJI assistant then reinstall firmware followed by all of your calibrations. IMU/Compass/gimbal
2016-8-13
mjlstudios
Flight distance : 1540131 ft
Its not the wind...check out the trees.
2016-8-14
caranod
gsxr07boy Posted at 2016-8-14 03:10
It's not wind 100% sure about that you could fly it in 45mph wind gusts and you will never see that  ...
Ok.  I'll do that today.
2016-8-14
MAD35
Flight distance : 4387201 ft
caranod Posted at 2016-8-14 20:24
I reckon it is the wind. Mine has done this also, both times it has been extremely windy.  In fact I flew today in a remote location and it was extremely windy in fact I am impressed the P4 made it through my flight.  This exact same thing happened today briefly half way through my flight.
Check out the footage, you can see how windy it is with the trees.  I edited out the gimble twitch.
2016-8-14
KensPhantom4
caranod Posted at 2016-8-13 18:33
Its the wind, monitor the water fall below and you can see the water spout to the right is bending in the wind, if you campare it to the other three water spouts, just as the camera tips back and forth, so does the water spout.
2016-8-14
