Genghis9
JUAN P4P Posted at 2017-9-9 10:32
i upgraded firmware with my original p4p controller usb-only module, then installed hdmi module and refreshed frimware, used an external hdmi monitor, and all worked well for 2 days, i had perfect usb feed to my iphone 6, and perfect hdmi signal to my external screen, but after 2 days, whenever i connect the controller with the external screen, i loose connection on the iphone 6, it is constantly going on a loop from weak connection signal to disconnected, and on the external screen it goes from input to no input, none of both devices ever shows a video feed at all, it just stays black!! i have tried reinstalling the original usb-only odule, and refreshing firmware and then again hdmio module install with firmware refresh, many times to no avail, many different cables, many different external screens! etc joi have done everything suggested from you guys!
Did you try resetting cameral settings or all settings. If not, give that a go, I read where some did so and it worked.
Best of Luck |
