DJI-H.C
Flight distance : 13602 ft
Hi, are you on the latest firmware? It's not normal, because the gimbal should be able to control the camera head to rotate over 45 degrees horizontally, something close to ±180 degree. Try reset the options in your DJI GO and try again. If it doesn't work, I suggest you contact support.eu@dji.com and send it in for repair. Thank you.
