update, change password wifi
1575 4 2016-8-14
lele2
Hi, i have make the update of the osmo.
Now the password of the wifi connection is changed,
before was 12341234, like you have register at the beginning, i was using 12341234.
After the upgrade the password is changed and i dont have...... can i know the news password?
tanks
2016-8-14
DJI-H.C
Flight distance : 13602 ft
Hi, please reset your wifi.
2016-8-14
lele2
DJI-H.C Posted at 2016-8-15 08:37
tanks for reaply, problem solved, but probabily the issue is another one, wifi signal is going off, on, is workin a minute, after is turnin off , this is happening after the update of the osmo.
2016-8-14
DJI-H.C
lele2 Posted at 2016-8-15 03:48
tanks for reaply, problem solved, but probabily the issue is another one, wifi signal is going off ...
No, it shouldn't happen. Try connect a device to your Osmo, and see if the image stays (instead of disconnecting after a while).  If that's the case, change to another phone and see if it happens again.
If it still happens, please contact support.eu@dji.com and send it in for repair. Thank you.
2016-8-14
duongduythao
Vietnam
Steps to change the wifi password is simple here:
Supports all types of wireless network modems
2018-4-13
