Minmim81
Flight distance : 7780965 ft
Inspire one pro black X5 with Olympus 12 mm Mzukio, but used to get great results on the X3 white inspire too.
In my experience with Agisoft The biggest problem causer is focal (x5) and I would aim to camera down 45° to minimise any background inclusion otherwise masking is good. and if you sequentially take pictures in an orbit then other guys overlap advice is the best otherwise if you're extracting from after affects video you can export 'nth' every frame. Experiment even on a decent laptop On agisoft, you should be able to get decent results in five or 10 minutes with six photos if that is not working then don't do it with 100 photos until your balance is right results can look beautiful. The other very important point is to make sure that your exposure is set to manual and as narrow contrast as possible before you colour correct for the texture layer remember that calculation layer will look different: 'Grayer' then the ones used for the texture layers, and you won't see it . If drone deploy is uploading your flight path mission, and is controlling your camera you will notice this exposure trick in the images that they take . the computer handles lower contrast better than grain or Unfocused images or high contrast, assuming it has points to recognise in contrast as an object . One last thing is that I get great results in overcast days where the lighting is diffused from the clouds but just take into account how are shadows if that is your shooting conditions or requirement. good luck!!! Fly up to the top or a little higher than the towers And aim downwards 45° is what I meant to say earlier otherwise the background will kill all your processing and you will never reach a result, and will never leave five or 6% completion |
