Compass not working
3020 11 2016-8-15
arturdebat
Flight distance : 421033 ft
Hi, I had a crash with the Phantom 3 Professional, I change the landing gears and the gimbal with the camera all buy it in the DJI store, but when I try to fly I have a error with the compass and I can't calibrate always have the same error about electromagnetics issues, I check the sensors and the compass is always 0 in all points, what I have to do? I can fix it by myself or I have to take to repair? I openened the case and check that all connections are connected, i don't see any issue, I don't know what to do.
2016-8-15
DJI-Ken
Flight distance : 1515312 ft
The compass is in the bottom right corner of the landing gear.
If the compass is plugged in correctly, then there has to be some internal damage. I would take it apart again just to make sure.
2016-8-15
arturdebat
DJI-Ken Posted at 2016-8-15 18:03
If the compass is plugged in correctl ...
ok, maybe is this because i don't know if i plugged correctly when i change the landings, you know how to do?
2016-8-15
DJI-Ken
arturdebat Posted at 2016-8-16 03:34
ok, maybe is this because i don't know if i plugged correctly when i change the landings, you know ...
Here is a photo of where the compass plugs into. The larger plug next to it is where the 4 video/RC antennas plug into. You probably just don't have the compass plug firmly seated.
2016-8-15
labroides
Flight distance : 9991457 ft
arturdebat Posted at 2016-8-16 05:34
As well as the top connection, there is also the bottom.
There are 4 fine wores going to the compass in the bottom of the landing gear.
Take the cover plate off the compass and check the 4 wires.
It's easy to break one when you fit the antenna in the landing gear.
2016-8-15
arturdebat
DJI-Ken Posted at 2016-8-15 22:20
Here is a photo of where the compass plugs into. The larger plug next to it is where the 4 video/R ...
Thanks DJI-Ken, I check inside the drone and the wire was connected correctly I didn't saw nothing wrong and the problem still continuous i can't calibrate the drone.
2016-8-15
DJI-Ken
arturdebat Posted at 2016-8-16 06:24
Thanks DJI-Ken, I check inside the drone and the wire was connected correctly I didn't saw nothing ...
I don't know what to say, I'm sorry, your crash must have done some internal damage.
2016-8-15
arturdebat
labroides@yahoo Posted at 2016-8-16 00:23
There are 4 fine wores going to the compa ...
I made this video for you if you can see some malfunction, but seems all is ok,  compass was sticky with this withe glue and when I change it I pull off to unhook and for the new legs I only put in the same place but without any glue or something, the compass have some rest of the old glue.
2016-8-16
arturdebat
Thanks for helping me
2016-8-16
04red6
Flight distance : 5484997 ft
Try a new compass and cable. You could have pulled a component loose when you pulled the glue off. Or one of the wires could be bad. It is a cheap try.
2016-8-16
darius.suddreth
FWIW all of the P3 series take the same compass..its DJI part 11
2016-8-16
arturdebat
04red6 Posted at 2016-8-16 18:08
Try a new compass and cable. You could have pulled a component loose when you pulled the glue off. O ...
Thanks, I will try this.
2016-8-18
