Positveimage
Flight distance : 2772 ft
Hi Guys,
I have just flown my brand new Inspire 1 after a long absence due to a crash. It is a brand new air frame and out of my first three flights, using the same battery, it failed to lower the landing gear, in return to home mode which the app had initiated, on the last one. It was really scary as its a brand new camera as well and I had to take control and make it hover whilst it attempted to land and catch it from below so it didnt crash on the gimbal.
I am getting re-used to the Inspire and taking everything really slowly so I am a bit put off by this issue.
The first two landings, in auto mode were on to hard ground whereas the third was onto short grass.
Return to home had been initiated automatically as I was letting the battery run down and even though the app said "landing gear is lowering" it was obvious it wasnt going to lower so I took control and caught the aircraft. Moments after the the power cut out.
Was it maybe that there wasn't enough power to lower the gear, even though the Inspire had initiated the return to home?
In the first two flights where the landing gear did lower, it seemed to be very near to the ground when it did so. I seem to remember it happening about 10 foot off the ground before.
Its a very hot day here and the battery temp reached 50 degrees... any bearing?
I have put a new battery on the aircraft and it will raise, lower and enter travel mode when using the remote control switch. I will fly it again tomorrow.
Many thanks
