Ronin MX Lightbridge 2
1872 5 2016-8-17
Motti7
Flight distance : 40976496 ft
I want to control my Ronin MX with the LB 2 controller and get video feed. So far I was able to get the video working (LB 2 air unit) but I can't figure out how to get the controller to work to move the gimbal. Do I need to hook up the dbus cable to the air unit (which I did, but could still not control the MX)?  Or do I need  to change some setting?
2016-8-17
DJI-Jamie
Flight distance : 112405 ft
To clarify, are you using this on a M600 or just on its own?
2016-8-18
Motti7
DJI-Jamie Posted at 2016-8-19 02:53
Just on its own.
2016-8-18
Motti7
Just on its own.
2016-8-18
DJI-Jamie
Are you able to select the "request controller" button in the RC settings of the Go app?
2016-8-18
Motti7
Thanks for your help, I got it working.  My question was if I have to use a dBus cable from the Ronin MX to the LB2 air unit. Yes I do have to connect the air unit with the dBus cable to the Ronin MX.  I was hoping the Ronin MX build in receiver can connect to the Lightbridge 2 TX controller (without connecting the air unit with the dBus cable).  Basically the LB2 air unit becomes the receiver for the Ronin MX, and the internal receiver still works with the Ronin MX controller.
2016-8-24
