robertstevenson
OK. Good News.
So I had possibly isolated the issue to when the thumb controller is on (while the Ronin M is on the stand if I try to pan or tilt it it accelerates and decelerates all of a sudden whilst at set full speed mid way through the pan, and is exactly the same issue for tilt)
NOTE : This periodic "Jerkyness"(as described above - AKA "sudden lunge") is also present while the thumb controller is on and the gimbal is trying to active track when motioning the gimbal to pan/tilt.
However - The gimbal showed no apparent issue when Responding to Gimbal input (EG Motioning Tilt of Pan on or off stand) IF THE THUMB CONTROLLER IS TURNED OFF
I also check pan and tilt with the Ronin M Full size remote control and the are no issues.
If I then turn the Ronin M Thumb controller on again the issue returns.
Note: (The Thumb Controller is currently Loader 1.0 Version 1.2 - Latest Version)
I Then plugged the Gimbal back in and noticed a new firmware version for the receiver
"CURRENT VERSION 1.0.0.12" -"NEW VERSION AVAIL" 1.1.0.15
Inline images 1
It is now operating smoothly when using the thumb controller and also on smooth-track when thumb controller on and not being used to move gimbal.
Thanks Team. |
