Compass Calibration with Gimbal
1082 3 2015-1-28
APWDave
Hi.
I always perform a compass calibration before every flight and I'm fine with the technique. The problem is that the Zenmuse will fight the movement of the quad whilst I'm turning it.
Will this damage the Gimbal? Is there a way of disabling it without unplugging it?
Cheers
Dave
http://aerialphotographywales.com
2015-1-28
markus2015
Hi Dave, you can't disable the gimbal, but if you do the turns and flip gently you should't have any problems with the gimbal fighting too much. No need to rush. But I do suppose it could bust the motors in the gimbal after a while.
2015-1-28
DJI-冬瑞
Hi Dave:
    In order to smoth the shot,the gimbal will fight agaist the aircraft a little bit.When the aircaft's movement is fierce,the video can keep smoth. So what you have  seen is normal.
2015-1-29
APWDave
Thanks Marcus. Slowly does it then. ;-)
Dave Powell
2015-2-9
