I have tried calibrate system and i have tried restore default settings on the DJI Assistant, but the out of control spin persists? has anybody come across this problem after disconnecting the Gimbal from the Handle Bar WHEN powered on? and if so any fix that you can recommend?
Are you able to access the Ronin Assistant app and enable Motor Kill? If you are able to, then you can attempt to reset the Ronin to defaul and calibrate the unit in the Assistant Software. To clarify, did the Ronin take a fall when it disconnected form the handle bars?
Hello Jamie, thank you for the feed back, no it did not take a fall when it was disconnected from the handle bars. i have enable Motor Kill and then "calibrate system" and "restore default settings" on the DJI Assistant and that has definitely helped as it has stopped the out of control spins. the problem now seems that the motors are very weak, and it looses balance quickly. see the video below
