Rotareneg
Flight distance : 676634 ft
They're pretty faint, you can see them in the trees on the bottom left. The lines happen if sunlight hits the lens directly with the props between the sun and lens. The props cause the glare to flicker rapidly which results in horizontal bars like due to the rolling shutter effect. If you use a neutral density filter the slower shutter speed can greatly reduce the effect. |
