Phantom not charging battery right out of box
3463 12 2016-8-19
scottybm
Flight distance : 1141201 ft
I work for a retailer where a client purchased a Phantom 4 and had trouble charging the battery. He said the lights would come on and after a few seconds would go out.
I told him to bring it back and we would replace it for him. So I pulled another one out and it did the same thing.
The charger would charge the radio just fine but both new Phantom 4's would do the same thing and not charge the battery.
Don't know if we just had a few that were bad or is this an issue with the Phantom 4
2016-8-19
nigelbrinkmann
Flight distance : 586391 ft
Maybe try and turn the battery on first then plug it in to the charger,
2016-8-19
nigelbrinkmann
While we are on the subject of charging, can DJI tell me if it is recommended to charge the controller and the flight battery at the same time, Iv done it several times in the past and noted that the charger gets warmer than just charging one item at a time, its obvious why but just need clarification, is it safe to do so all the time?
2016-8-19
Geebax
nigelbrinkmann Posted at 2016-8-20 15:54
While we are on the subject of charging, can DJI tell me if it is recommended to charge the controll ...
DJI recommend you do not charge the RC unit and a battery at the same time. It is close to overloading the charger.
2016-8-19
DJI-Paladin
Flight distance : 2408 ft
Hello Scott, it is not normal.If these batteries don't work with other chargers, you'd better to send it in.
2016-8-19
pan.papandreou
Greece
DJI-Paladin Posted at 2016-8-20 09:49
Hello Scott, it is not normal.If these batteries don't work with other chargers, you'd better to sen ...
What I saw in the video do BATTERIES for protection when hot. WHEN COLD Charges normally (sory google tranlete greece)
2016-8-20
pan.papandreou
Greece
Try froze a little battery and charger again
2016-8-20
DJI-Paladin
pan.papandreou@ Posted at 2016-8-20 16:29
What I saw in the video do BATTERIES for protection when hot. WHEN COLD Charges normally (sory goo ...
2016-8-20
scottybm
nigelbrinkmann Posted at 2016-8-20 13:46
Did that. Turned battery on and then tried to charge. The green ring just stayed on for a minute then went off.
2016-8-20
scottybm
nigelbrinkmann Posted at 2016-8-20 13:54
From what I read on my Phantom 3 it says not to do that. And when I called DJI about this issue they said you may not want to try to charge them both.
2016-8-20
scottybm
DJI-Paladin Posted at 2016-8-20 14:49
We have just sent both units back. Thanks DJI-Paladin
2016-8-20
thomas
Flight distance : 195030 ft
Hi DJI, I have the same issue right now. Faulty batch perhaps? Maybe faulty sensor? How can I send back direct to you?
2016-8-20
DJI-H.C
Flight distance : 13602 ft
thomas@luxton.u Posted at 2016-8-21 15:30
Hi DJI, I have the same issue right now. Faulty batch perhaps? Maybe faulty sensor? How can I send b ...
Hi, the most common reason is that the retailer put the drones idle for too long, and the batteries died  when not being used for a couple of months.  Please contact the seller to see if you can do a direct exchange, if not, contact support.eu@dji.com and send it in for exchange. Thank you.
2016-8-21
