First flights M600 no problem
973 6 2016-8-20
N800UA
Hi.
just wanted to report my first 3 flights with M600 with Zenmuse Z15 5D3HD have been error free mostly.  The gimbal seems to want to have tilted horizon.  I calibrate and it's ok but then it returns.  I am only single operator so gimbal only pitches up and down to the front which is normal I believe.
2016-8-20
DJI-Jamie
Flight distance : 112405 ft
Does the gimbal seem balanced? Are you using one of the recommended lenses?
2016-8-21
N800UA
Hi...
Yes the gimbal seems balanced and I am using ONLY the DJI recommended lens for this camera/gimbal combination.  When it starts up it is turned about 4 degrees to the left and the horizon is off a little bit.  Seems to correct after I calibrate but seems to require calibration every flight or power down and restart.
2016-8-24
DJI-Jamie
N800UA Posted at 2016-8-25 02:34
Hi...
Yes the gimbal seems balanced and I am using ONLY the DJI recommended lens for this camera/gim ...
Do you happen to notice whether this occurs in either H-Free or in H-Trace? Just to clarify, would you perform an IMU calibration and gimbal calibration in that order? If you have done that and all the firmware is up to date, then the Z15 may need to come in for additional service. They do have access to equipment that can fine tune the gimbal and alleviate the issue.
2016-8-24
N800UA
DJI-Jamie Posted at 2016-8-25 06:23
Do you happen to notice whether this occurs in either H-Free or in H-Trace? Just to clarify, would ...
Hi.. I am un-sure what H-Free or H-Trace means.   The problem has not gone away.  Sorry I am slow responding.  Just busy.
2016-9-3
johnbarr00
Love my M600, 6 flights in with ZERO issues. Full 30 minute flight time with A7RII on MX.
2016-9-5
DJI-Jamie
N800UA Posted at 2016-9-4 01:30
Hi.. I am un-sure what H-Free or H-Trace means.   The problem has not gone away.  Sorry I am slow  ...
H-Free means that the gimbal is not orientation locked and H-Trace is when the gimbal is orientation locked. Could you happen to provide a small video on the issue in order to see the extent of the tilting? Have you looked into a potential repair service with the North American Support Center as well?
2016-9-7
