Galaxy tab 4 not working
659 5 2016-8-22
killerkustums
Hi guy's. I having trouble getting my tab 4 to run my p4.  Has anybodyn had any experience getting to run with a p4? Thanks guy for the help.
2016-8-22
mjanzou
Flight distance : 14820 ft
DJI GO on android is still not 100% compatible with marshmallow version 6.0+
However it has been working with my galaxy tab s2 running android 6.0.1 with the known 'default set' issue, I use DJI UF 99% so no big deal for me.
2016-8-22
DJI-Paladin
Flight distance : 2408 ft
Hello killerkustums, first,for samsung device, please make sure USB debugging mode and MTP mode are enabled before enter the camera view. But If it is convenient, I'd suggest you to try with these devices: 兼容列表.JPG
2016-8-23
mmarkoe
Flight distance : 15135 ft
I was using a Samsung Tab A without a problem before the marshmallow update. What I finally figured out, is to first enable USB debugging. Next start by enabling RNDIS. This is a little bit tricky as sometimes it defaults back to USB charging or MTP. A little bit of trial and error will get this to work. However you will need to do this prior to any time you restart the DJI Go app.
Marty
2016-8-23
killerkustums
DJI-Paladin Posted at 2016-8-23 04:58
Hello killerkustums, first,for samsung device, please make sure USB debugging mode and MTP mode are  ...
I'm running android 6.0.1   .   this may be the problem isn't it?
2016-8-23
DJI-Ken
Flight distance : 1515312 ft
killerkustums Posted at 2016-8-23 21:09
I'm on 6.0.1 and it's working fine on my Samsung S6, since the Tab A is not on the DJI list I cannot say why it is not working. If the suggestions in the above post do not work, try a difference device.
2016-8-23
