gannonhall
Flight distance : 2283 ft
I've been banging my head against a wall for days now trying to upgrade the firmware of my Inspire 1 w/ zenmuse X5 (Raw) I think it's called now. The Zenmuse was an upgrade from the stock inspire 1 camera. I upgraded the firmware of the controller, quad, camera and batteries a few months ago. I was going to use it for the first time since then and the go app tells me to upgrade the firmware of my controller. I do this. Then DJI Go tells me the inspire and camera firmware need upgrading. So, as I've done countless times before I download the latest firmware fromhttp://www.dji.com/product/inspire-1-pro-and-raw/info (Inspire 1 RAW Firmware v01.09.01.30), unzip the archive, copy the .bin file to an sd card, put the SD card in the camera, and with the controller off, start up the inspire (with a full battery). The inspire does its start-up dance (the camera moves around), then makes the beep.... beep, beep sound. But then the LED flashes Red. It does not flash red, green, red, green as it is supposed to while it's doing a firmware upgrade (or the way it used to work. I've tried a different SD card. Tried a different battery. Reconnected the camera... nothing works. I also just tried running it (thinking the red flashing was the new firmware loading color. The battery ran out eventually. Now I have it doing it again. It just flashes red. Any ideas?
