MGR57
From the FAA Web-site for sUAS operators.
Operating Requirements
The small UAS operator manipulating the controls of a drone should always avoid manned aircraft and never operate in a careless or reckless manner. You must keep your drone within sight. Alternatively, if you use First Person View or similar technology, you must have a visual observer always keep your aircraft within unaided sight (for example, no binoculars). However, even if you use a visual observer, you must still keep your unmanned aircraft close enough to be able to see it if something unexpected happens. Neither you nor a visual observer can be responsible for more than one unmanned aircraft operation at a time.
You can fly during daylight or in twilight (30 minutes before official sunrise to 30 minutes after official sunset, local time) with appropriate anti-collision lighting. Minimum weather visibility is three miles from your control station. The maximum allowable altitude is 400 feet above the ground, and higher if your drone remains within 400 feet of a structure. The maximum speed is 100 mph (87 knots).
You can’t fly a small UAS over anyone who is not directly participating in the operation, not under a covered structure, or not inside a covered stationary vehicle. No operations from a moving vehicle are allowed unless you are flying over a sparsely populated area.
Operations in Class G airspace are allowed without air traffic control permission. Operations in Class B, C, D and E airspace need ATC approval. See Chapter 14 in the Pilot's Handbook (PDF). |
