Active Track not Fully Working on new Phantom 4?
2368 9 2016-8-23
genshi
Flight distance : 8415 ft
Sorry, I tried searching for this specific issue with no luck... I can't seem to get Active Track to fully work on my new DJI Phantom 4. I can select a subject (always a person) and it gives me the green "GO" indicator, and it will spin around in place tracking that person, but it never moves forward (or back) to actually follow the person to where they go; the P4 just stays in one place spinning left or right only to track my subject. Is there a setting I'm missing? Or a bug/defect? I just bougth this last week and have all the latest updates.
Thanks in advance for any help or guidance!
2016-8-23
andy
Flight distance : 3358875 ft
I've seen this on my P4.  I can't remember how I solved it though, my notebook is back home in the office.  I think it was a setting in DJI Go somewhere, but I'll have to check when I get home this evening.
Andy
2016-8-24
Aardvark
Flight distance : 384432 ft
Highlight the object to track and then you need to tap green box to activate the tracking.
2016-8-24
Cetaman
Flight distance : 2494390 ft
Aloha genshi,
     What they said, also you need to be 5 or 10 meters away (I forget which) from the subject when you set the connection or it will not follow.  Probably a safety issue.
Aloha and Drone On!
2016-8-24
DJI-Paladin
Flight distance : 2408 ft
Hope these 2 videos can help you:
2016-8-24
genshi
Aardvark Posted at 2016-8-24 16:55
Watched a weeks worth of tutorials before I even bought it, did exactly as you mentioned (Highlight the subject, tap the green box) and was a safe distance away... tried 8 times with no luck. Everything else seems to work, orbiting a Point of Interest, TaptoFly, etc.
2016-8-24
Aardvark
genshi Posted at 2016-8-24 13:16
Watched a weeks worth of tutorials before I even bought it, did exactly as you mentioned (Highligh ...
That's weird, I remember the first time I used it, highlighted object (a friend of mine) and it hovered with the gimbal moving and aircraft rotating, the camera was following object but aircraft was not moving. All came right when I taped on the highlighted area.
Just as a thought you say safe distance, it needs to be at least 9 feet above ground level to work.
2016-8-24
nigelbrinkmann
Flight distance : 586391 ft
genshi Posted at 2016-8-24 20:16
Hi, so you can get the green 'go' box to appear? is the the green 'go' button alongside/outside of the green highlighted subject,or is the 'go' button within the green highlighted subject box?
2016-8-24
genshi
nigelbrinkmann Posted at 2016-8-24 21:22
Hi, so you can get the green 'go' box to appear? is the the green 'go' button alongside/outside of ...
The green Go is on the side of the highlighted subject box. Maybe I didn't "tap" it correctly? I'll try again later this afternoon...
2016-8-24
fans410b3367
Flight distance : 5723425 ft
same happen to me, i do all proceed and nothing happen
2017-2-8
