markaguille
Flight distance : 2031818 ft
Jersey
Always take off and land "tail in" catching the battery from underneath with gear up. Whilst holding the bird still above your head, pull back on the left stick to lower the gear. There is a lot of talk about switching of VPS when flying above water, personally, I have more than 400 flights over open water with VPS on and have zero issues. Just be aware that the height of the water may be constantly changing so when flying low, make sure you are not in it. I have never had switch to ATTI to take off and if hand launching this should not be a problem.
Good luck and keep us posted.
Mark G. |
