GabeZ
Flight distance : 768448 ft
I don't know if anyone else has noticed this, but the go app draws a blue circle around the circumference of the horizon/position bubble when you pan the camera. When you pan one way, the blue line makes it to the proper stopping point. However, when you pan the other way, it falls short of the stopping point before it hits the limit. One other thing I noticed is that each time you reset the camera to center, it somewhat drifts to a rest (meaning the ribbon must be wound tight and center is not true center until it slowly drifts into place). Another little annoying tidbit is that the camera pan twitches when you do CSC (like it tried to compensate for movement that wasn't there). |
