My Quick fix for osmo tilt
2685 6 2016-8-27
userc1f1dd8467
United Arab Emirates
Hi everyone,
Ive had my osmo for about 4 months now and learned how to deal with the tilt.
My quick fix is, once you power on your osmo 5 times out of 10 its gona have the infamous tilt.
Step 1: triple press the front hold button to make it go into selfie mode.
Step2: double press the same button to return the gimbal to its normal orientation. ( 9 out of 10 times this will fix my tilt )
If for some reason it didnt work repeat the 2 steps.
Note: this is only to fix the tilt problem and not the drift.
Hope this helps !
2016-8-27
DJI-H.C
Flight distance : 13602 ft
Thanks for sharing your experience.
2016-8-28
projectorize
Norway
Tilt, or pan?
2016-8-28
nigelbrinkmann
Flight distance : 586391 ft
Tilt only.
By moving the gimbal full rotation in each direction can help to, the method mentioned in post one is a faster way of doing it.
2016-8-28
projectorize
Norway
So whats the problem with the tilt, not working?
2016-8-28
H DRONES
projectorize@gm Posted at 2016-8-28 15:45
Tilt, or pan?
The horizontel tilt
2016-8-28
projectorize
Norway
So its the roll axis youre referring to then...
2016-8-28
