FPV for Phantom 2-Zenmuse Gimble with GoPro
580 0 2016-8-27
kabbott622
I just bought this Drone off of a Local classifieds.  Came with a whole FPV system.
Here is a list of all the Equipment in the set up:
Transmitter: 5.8GHz 600mW A/V Tx from Immersion RC.  I looked up how to wire it into the drone and they wired it correctly.
Zenmuse Gimble with the GoPro (I know not to use the wifi on the GoPro)
RC832 Receiver
Then just a little 7" TV that has an A/V input in that comes from the receiver.
When I have everything hooked up and everything on the same channel, on the TV it says that theres no signal... Blue screen essentially.
For there to be a signal on the monitor, do the transmitter and the receiver have to connect or should the receiver be transmitting "static" even if its not connected to anything?
Im just trying to figure out if I'm doing it wrong or if some of the equipment doesn't work. Any advice helps.  Thanks!
2016-8-27
