DJI GO causing Samsung S7 to restart
67406 422 2016-8-28
leemerc
Flight distance : 865236 ft
Not sure if all these facts have been stated.
This affects DJI go as well as LITCHI and DJI Ultimate flight apps. It affects all models of DJI drones including WI FI and lightbridge.
My Samsung Galaxy tablets are not affected (yet!) Only the s7 phone
Has the recent apple upgrades got anything to do with this?
2016-9-19
claw
Poland
I reported the problem to samsung . They wrote to reset the phone to factory settings. if reset does not help to provide telephone service.
Restet phone did not help. I provided the phone to an authorized service.
I received a phone reset to factory settings. Samsung said that it can not install an older version of the firmware . Again I contacted the helpdesk samsung . They wrote that download a previous firmware version is associated with the loss of warranty, and authorised service did not perform it . At the end they added that the problem is with the application DJI him and the problem should be reported to the DJI.
At present I dowgrade firmware, my phone works correctly. Thanks to Pawel
2016-9-20
kirk2579
Flight distance : 37415 ft
lightningshark Posted at 2016-9-20 02:13
I highly doubt that a factory reset alone would have addressed this issue..
A factory reset would ...
"A factory reset would not remove the Samsung firmware updates - it returns the phone back to the firmware as it was installed "
I honestly do not know this but if it truly restores to factory image firmware ,
would that also not remove any updates that were not factory level installed.
2016-9-20
userfdb17a1bb9
Only s7 EDGE or s7 standard also ?????
Anyone knows?????
2016-9-20
usera091b2c02d
Philippines
Mine is an S7 standard and has the same prob
2016-9-20
lightningshark
Flight distance : 1398 ft
kirk2579@aol.co Posted at 2016-9-20 22:32
"A factory reset would not remove the Samsung firmware updates - it returns the phone back to the  ...
I could put it clearer - I wouldn't expect the factory reset on the phone would touch the firmware version at all.  It would affect the user data and applications part of the installation.
In the case where firmware updates have been done I expect these to stay after the factory reset.  "firmware as it was installed" would include any firmware updates.
I could see that if the firmware update ALSO made a configuration change that caused the problem .. maybe a firmware reset would roll the settings back.  Sadly a number of people have tried the factory reset now, and it looks like it didn't fix it - so the issue seems to be somewhere in the firmware and its compatibility with the DJI apps.
2016-9-20
lightningshark
claw@ox.pl Posted at 2016-9-20 22:19
I reported the problem to samsung . They wrote to reset the phone to factory settings. if reset does ...
Good to hear you got it working!
So some evidence of Samsung pointing the fingers at DJI - this issue may take a long time to get solved!
An application - even if it does cause a fault - should not cause the phone to crash.
There is clearly an issue with Samsung's firmware or Android OS
That said - DJI might still be able to debug and come up with a workaround to get their customers up and flying again?
2016-9-20
dennisvourtsis
Greece
Just flashed to a rom that was released early in August and works fantastic like it should.Tried Litchi and that works fine to.Will just have to wait until they sort it out then i will update.followed pawlovs instructions.
2016-9-21
userfdb17a1bb9
I think about selling my s7edge and buying a Sony z5.
Any experiences with sony z5 at this moment with dji go?
2016-9-21
ericnietodesand
I had the Z3 compact, and worked perfectly with my phantom 4, but I broke it and bought a S7, thinking that samsung was a great company..
If it worked well with the Z3 compact it have to be better with the Z5
2016-9-21
leemerc
Are Samsung busy with exploding phones and a humungous re call? Hellooooo Samsung?
2016-9-21
leemerc
Have emailed Ken the developer of the fantastic app DJI Ultimate. He replied but had no answer or suggestions............what hope have I got then of fixing it?
2016-9-21
5Uw3QnedyFpZ
Same issue here. So frustrating. I actually bought the S7 because I had a BQ Aquaris phone that didn't work that well and I thought the latest and the best of smartphones today can work perfectly with the drone. But no...
Sometimes though it works just fine, but then it restarts the phone and hell breaks loose. Yesterday I set up the drone to follow me, then phone restarted and after it did I opened the DJI app again while the drone was in the air, and as soon as  I opened the app the drone flew away from me at high speeds. It took me 5 minutes to be able to get it back because for some reason it was flying away from me on its own and I just could not stop it from doing that. Not sure what the heck happened but it was super scary. Is the drone suppose to follow you even if the app closes or when you loose the signal on the phone from the downlink?
2016-9-22
userfdb17a1bb9
Any News out there? It couldnt be true that we owners of the actual s7 and s7 edge series are totally f!cked up!!!!
2016-9-22
leemerc
Atm being a Samsung S7 owner is like being a man with no arms clapping
2016-9-22
DJI-Ken
Flight distance : 1515312 ft
lightningshark Posted at 2016-9-21 09:47
So some evidence of Samsung pointing the fingers at DJI - this i ...
The S7 not working with the app has noting to do with DJI and is a fix that Samsung needs to do.
The incompatibility issue is caused by the Samsung S7 mobile system. DJI has urged Samsung to solve this problem a.s.a.p..
2016-9-22
Benjamin_Harris
Flight distance : 135476 ft
DJI-Ken Posted at 2016-9-23 05:28
T ...
Thanks for this confirmation DJI-Ken
We all await the update from Samsung
2016-9-22
DJI-Ken
Benjamin_Harris Posted at 2016-9-23 09:42
Hopefully Samsung has a fix soon.
2016-9-22
leemerc
DJI-Ken Posted at 2016-9-23 12:54
Samsung are pretty busy atm with exploding phones
2016-9-23
ericnietodesand
DJI-Ken Posted at 2016-9-22 23:28
T ...
thanks for asking them it, we tried to do it but they didn't listened to us.
I hope this will be fixed soon
2016-9-23
dinayanurpamuji
Indonesia
Yg pakai s7 ga bisa terbang
2016-9-23
userfdb17a1bb9
It really seems to be a "Samsung-only" Problem.
Ive bought a Sony Z5 yesterday and today i flight the 3rd time without any problems. Theres android 6.0.1 on it.
Absolutly no reboots or someting else.
PS
Thanks for asking Samsung.
2016-9-23
3LKdmyveFTRA
Flight distance : 330528 ft
Possible good news everyone. Woke up this morning and there was a new update for my S7 Edge. Maybe this is fix we all have been waiting for.
2016-9-23
userb56e12694d
go to Settings - Developer Options - off everything...perfect
2016-9-23
DJI-Ken
userfdb17a1bb9 Posted at 2016-9-23 19:50
Ive bought a Sony Z5 yesterday and today i flight th ...
That is correct, it's a Samsung issue and not a DJI issue.
2016-9-23
DJI-Ken
3LKdmyveFTRA Posted at 2016-9-23 20:35
Possible good news everyone. Woke up this morning and there was a new update for my S7 Edge. Maybe t ...
That's great, hope all works well now.
2016-9-23
DJI-Ken
userb56e12694d Posted at 2016-9-23 21:28
Is that before the latest update or after?
2016-9-23
DJI-Ken
leemerc@bigpond Posted at 2016-9-23 16:37
It may have been resolved, check the Go app on your S7.
2016-9-23
userfdb17a1bb9
@userb56e1269
Settings -Developer Options - off everything... perfect???
Can you explain it please?
2016-9-23
userfdb17a1bb9
@userb56e1269
PS
In germany there isnt an update for the s7edge today. Also not for the dji go
2016-9-23
userfdb17a1bb9
Only turn off the developer options on my s7 edge ?
2016-9-23
Presidente
Take these steps ... problem solved
2016-9-23
Presidente
DJI-Ken Posted at 2016-9-23 16:39
6.0.1 update
2016-9-23
DJI-Ken
userfdb17a1bb9 Posted at 2016-9-23 23:01
@userb56e1269
There wouldn't be a GO update for this as this has to be fixed by Samsung and not DJi.
2016-9-23
Presidente
userfdb17a1bb9 Posted at 2016-9-23 17:10
yes. I posted how to do it with a screenshot ... s7 firmware 6.0.1
2016-9-23
DJI-Ken
Presidente Posted at 2016-9-24 03:26
That is great it's working for you.
2016-9-23
userfdb17a1bb9
I cant see a screenshot here. But when its really so easy to kill the developer-options, so this is to nice to be true
2016-9-23
Presidente
userfdb17a1bb9 Posted at 2016-9-23 21:54
I cant see a screenshot here. But when its really so easy to kill the developer-options, so this is  ...
2016-9-23
userfdb17a1bb9
Thanks for the screenshots. It was my bad. Ive seen the mobile version of this site not the pc-version. Thanks for this. Im cant wait until tomorrow to seen the result
2016-9-23
ericnietodesand
I don't know if this will be the solution.. because I had this disabled when I started to have this problem, I activated it for trying to solve but it didn't worked
2016-9-23
