Anyone take the Part 107 test today?
12Next >
9117 54 2016-8-29
adam1
Flight distance : 326421 ft
well, let's hear about it... Hard, easy, blab bla bla
2016-8-29
Jkeller84
Flight distance : 396955 ft
I just got done. It was easy if you study the material.
2016-8-29
johnbarr00
I am going to take it in two hours, I will update you afterwards!
2016-8-29
johnbarr00
Just found this information, which is concerning
https://www.dartdrones.com/10-ta ... nowledge-test-suas/
2016-8-29
adam1
johnbarr00@gmai Posted at 2016-8-29 14:06
https://www.dartdrones.com/10-take-aways-completin ...
Not discounting the article, nor the site it was published on...  It seems to be a testimonial for DartDrones.  I'm sure the truth is somewhere in between.  Although, I'll bet their course couldn't hurt!
2016-8-29
LICENSED PILOT
Flight distance : 692090 ft
Completed my FAA part 107 exam today. Scored a 73% with little studying (to be truthful, I do hold a commercial pilot certificate). Took me 45 minutes.
Lots of questions on airspace, weather reports (learn to read the TAR on page 15 of the testing supplement, up/down, front and backwards)
Learn to pick out your BCDE airspaces from aeronautical charts (bottom and ceiling)
Aeronautical decision making; lots of questions on this.
2016-8-29
SamEAS
Finished it. I was thinking that a lot of the people that have had no former ground school or pilot training will struggle with some of the questions to the point that they may not pass.
2016-8-29
smcfan
Flight distance : 14961 ft
Took it this morning. Passed with a 94. Study the material and you will be fine. A couple of questions I had not seen any material on so that tripped me up. I'm sure its out there, I just missed it.
2016-8-29
johnbarr00
I passed the exam with a 77%. I have no background in aviation. I have been flying drones for 2+ years now. DartDrones.com study helped me a lot with concepts that are otherwise foreign. I will say the test was not easy and not to be taken lightly. Very excited to use my new certificate with my Matrice 600!
2016-8-29
RichJ53
Flight distance : 1837356 ft
LICENSED PILOT Posted at 2016-8-29 12:34
Completed my FAA part 107 exam today. Scored a 73% with little studying (to be truthful, I do hold a ...
LP
did you take this online using your airman cert? Looks like the airman test is different from the new UAV pilot test.
Rich
2016-8-29
techmyjustin
Flight distance : 191896 ft
What is the minimum passing grade?
2016-8-29
PeteGould
techmyjustin Posted at 2016-8-30 11:53
Minimum passing grade is 70.  I took it yesterday and scored an 88.  I've been a private pilot since 1993 but I'm not currently active (way too expensive to fly these days), so since I don't have a current biennial flight review I took the Part 107 test at a test center.
Let me assure anyone considering it: this test is no joke.  There is an enormous emphasis on reading navigation charts and determining airspace.
There will be questions like this one (this is similar but not identical to an actual question): "Refer to the navigation chart in Figure X.  Locate the tallest radio tower four nautical miles southeast of XYZ airport.  Would you need FAA authorization to fly at the maximum permissible altitude above the radio tower?"  The correct answer turns out to be "Yes, because you are entering Class B airspace."  This requires not only that you know you can fly up to 400' above a structure but also understanding the chart symbols and notations to determine the resulting altitude, then realizing that flying 400' above the radio tower puts you roughly 100' above the floor of Class B airspace surrounding an airport several miles away.
Another question asks something like "Refer to Figure ABC.  If the tower at XXX airport is closed, what radio frequency must you tune to in order to monitor aircraft communications at this airport?"  When you find the airport there are numerous radio frequencies listed and you need to know the symbol that indicates the CTAF frequency that will be used if the tower is closed.  (Don't know what CTAF means?  You may not be ready to take the test yet).
The notations on sectional charts are arcane and there were at least 20 questions involving such charts, along with lots of other questions on Part 107 issues (total of 60 questions, NONE of which were giveaways).  I normally ace multiple-choice tests, including very difficult ones.  I consider 88 a very low score (although it was more than passing) - and I did a lot of prep for the test, AND had the private pilot background.
Keep in mind that tests are dynamically created from a bank of thousands of questions, so your questions may not include anything like the two examples above.  I'm just using them to illustrate the level of difficulty you can anticipate.
I found the level of security at the test center almost astonishing, as though I was obtaining authorization receive the nuclear codes.  Our test center was only large enough for three candidates.  It was on constant recorded video and audio surveillance, with the proctor outside the room watching the monitors.  We were not allowed to bring anything into the test room - no scratch paper, no pens, no pencils, no calculators, nothing.  The test center supplied three pencils and scratch paper.  A calculator was built into the test software.  There were big signs warning about all the "MUST NOT's."  We were told if we exited the room to use the bathroom without authorization we would instantly fail.  We were allowed to say only two things aloud: "I need a break" or "Test Completed."  Anything else would result in a fail.  If you needed a break you said so and the proctor would escort you to the bathroom and back.
Take it seriously, do a lot of preparation including learning to read sectional charts, and you should do fine.
2016-8-30
pidetectives
Flight distance : 2131073 ft
Just took the test this morning and O BOY did a flunk the test.Only three to four questions I remembered from the studies. Having to pay another $150 is whats killing me.
Now my two thoughts. I belive that the FAAhas made it hard to get the certificate  to discurage thousand that are geting the license just to get it and not folow the rules. Those that are serious about this carrier will study hard and if the fail, pay another $150and study harder.
2016-8-30
LICENSED PILOT
RichJ53 Posted at 2016-8-30 10:10
LP
did you take this online using your airman cert? Looks like the airman test is different from t ...
nope, decided it's not worth the $$$$ it takes for a BFR/renting a plane...since I am not an active pilot any longer. Cheaper to go 107.
2016-8-30
LICENSED PILOT
PeteGould Posted at 2016-8-30 18:06
Minimum passing grade is 70.  I took it yesterday and scored an 88.  I've been a private pilot sin ...
"I found the level of security at the test center almost astonishing, as though I was obtaining authorization receive the nuclear codes.  "
I felt the same way, the lady even took my baseball cap and my wallet! I thought she was giving me access to Clinton's emails
BTW, no joke, you better study....
2016-8-30
LICENSED PILOT
pidetectives@ya Posted at 2016-8-31 00:03
Just took the test this morning and O BOY did a flunk the test.Only three to four questions I rememb ...
Sorry. The $150 every time is outrageous and a scam....
2016-8-30
LICENSED PILOT
LICENSED PILOT Posted at 2016-8-30 03:34
It has been 25 hours since I completed the exam. I guess they are not kidding about the 24-48 hours to process your certificate application via IACRA...
2016-8-30
ctUTAJiRASQd
I did take the test yesterday, and spent a lot of time flipping to, and reading the sectional charts.    I have no aviation experience and have never flown a drone, but passed with an 85%.
The test was harder than I expected, and I missed at least one or two answers by giving the Part 101 answer rather than the Part 107 answer.   (Which drones need to be registered?  For Part 107, even drones under .55 lbs have to be registered!)
I missed another by messing myself up on time conversions.
There were several questions that tested multiple knowledge items in one.
Get to know the Sectionals - Remember there is a key to reading the sectionals near the front of the reference book you are given for taking the test.
I finished in about 45 minutes, there is no need to rush in taking the test.
2016-8-30
RichJ53
PeteGould Posted at 2016-8-30 03:06
nice summary Pete and thank you
Rich
2016-8-30
RichJ53
LICENSED PILOT Posted at 2016-8-30 12:46
nope, decided it's not worth the $$$$ it takes for a BFR/renting a plane...since I am not an activ ...
LP you are correct, I am retired too and this might be to much money to go that way. We  do not have any test centers where I live
Rich
2016-8-30
PeteGould
LICENSED PILOT Posted at 2016-8-31 03:50
Not really.  The tests are privately administered.  The company that administers them, that provides the space, pays for the required surveillance equipment, that provides the proctor to supervise, is entitled to be paid every time its facilities are used.  It's not THEIR fault if someone needs a retest, and they should not be required to provide time, facilities and resources without compensation.  If the FAA administered the tests directly I might have a different opinion, but they can't force private companies to provide service for free.
2016-8-31
BIGDZ
Flight distance : 10255860 ft
pidetectives@ya Posted at 2016-8-30 09:03
Wait... You have to pay again if you fail.
2016-8-31
BIGDZ
My test is scheduled for this Friday, been studying for a bit, also purchased the remotepilot101.com course study, which really been helping me for the exam....I'm not a good test taker but I  feel confident and prepared, so will see...
2016-8-31
PeteGould
BIGDZ Posted at 2016-8-31 21:06
Yep.  $150 each time you take the test, regardless of grade.
2016-8-31
LICENSED PILOT
PeteGould Posted at 2016-8-31 21:50
THE END GAME
2016-8-31
pidetectives
BIGDZ Posted at 2016-8-31 21:10
My test is scheduled for this Friday, been studying for a bit, also purchased the remotepilot101.com ...
I studied from pilot101 and I can tell you I flunked the test yesterday with a 47 score
2016-8-31
pidetectives
every time you fail yes $150
2016-8-31
pidetectives
The questions come from a bank the FAA has. Everyone's test is different. Some like my self will get a lot of chart questions others will not.
Is there a Book that I can buy that wil help with this.?
2016-8-31
BIGDZ
pidetectives@ya Posted at 2016-8-31 23:45
The questions come from a bank the FAA has. Everyone's test is different. Some like my self will get ...
I went to YouTube, and searched for how to read VFR charts. Tons of video popped up, I'm not just relying on remote pilot101.
2016-8-31
DAP.UAV
Flight distance : 3016014 ft
Took my test on Monday.  92%.  It did take just over 30hrs to get my test uploaded to the FAA.  Got my Temp Cert today.  Not too bad.  I am a Private Pilot with Instrument rating but not current.  Like some stated above, it's been too expensive to fly manned aircraft.  For those of you who are not familiar with this information, a company that provides study material in aviation called ASA Aviation does have a UAV study guide/practice test for Part 107.  They have several methods both online, ebook and hard cover.  They have practice tests as well.  Check it out.  Do not take this test lightly.  I expect many will be surprised at the level of difficulty.  I will say the ASA study guide and test, which I used, will cover everything you need to know to pass the test.  No I do not work for them.  Just trying to help.  Maybe save someone having to retest for another $150.
2016-8-31
pidetectives
BIGDZ Posted at 2016-9-1 00:01
I went to YouTube, and searched for how to read VFR charts. Tons of video popped up, I'm not just  ...
Thanks will do that
2016-8-31
PeteGould
The specific questions will change but the topics will not - each test is likely to have roughly the same number of chart questions.  They'll just be different ones.  It's clear that the FAA is putting a huge emphasis on knowing where you can and can't fly.
2016-8-31
SkySight
Flight distance : 143566828 ft
I've got my multi, commercial, Instrument so does this mean I'll have an additional addon to my actual license? I wonder if they will mail me a new plastic pilot license with the rating added. Type Ratings don't go on it so I don't know. My buddy asked me if we get to log UAV time as flight time to bump up the total flight time in our log book. lol I can't imagine trying to log any of this stuff with no airports to put in the logbook.
I'm not current. So, I'm taking the test in the morning. Been using the Prepware Remote Pilot App to study. I keep getting around an 80 on their test. I hope its not missing something, lol. I'm also doing the medical before the test. Did you all do the medical. I'm doing Second Class. I don't think I need a First Class, right?
2016-9-1
PeteGould
SkySight Posted at 2016-9-1 17:32
I've got my multi, commercial, Instrument so does this mean I'll have an additional addon to my actu ...
I have my PP-ASEL but no current BFR so I took the test under Part 107.  Although the Part 107 and PP-ASEL certificates are both associated with my FAA account it appears that they will be separate certificates.  I won't know for certain until the permanent card arrives - for now I just have the Temporary Airman Certificate for Part 107.
No Medical is required under Part 107.  Operators self-certify.
I sincerely doubt you can log the time because you are flying as RPIC, which is different from PIC.
2016-9-1
pidetectives
Anyone know if there Are VFR for Dummies book out there? I am having a hard time understanding VFR
2016-9-1
Drew Vallejo
I ended up taking it today and passing with an 80%. I studied all the material and used a couple different Youtube videos to fill in the gaps (G and E airspace, Sectional charts). I didn't have any prior knowledge of most of the material but can definitely see why it is all important to know. I will say that the main parts that tripped me up personally, were the questions on what I considered minor stuff (CRM and which handbooks to find different info). All in all it was a good experience. Just take the time you need to prepare, you can always reschedule until you feel ready. Good luck!
2016-9-1
howie121218
Can anyone passed the test could share some prep materials please?
2016-9-1
howie121218
do you think it's worth $300 to take those courses?
http://www.dronepilotgroundschool.com/curriculum/
2016-9-1
Drew Vallejo
howie121218@gma Posted at 2016-9-2 03:40
Your best route is to go on the FAA website and get all the training material from there. There aren't any real shortcuts to the test or studying. You have to go over all the material and get to know it really well. With that said, I'm sure that training course you mentioned has a lot of great information. $300 is a lot to spend though (when you can find it all for free) and in my experience, some of the questions are lines right out of the material. Not sure it would be exactly the same out of the course.
2016-9-1
howie121218
Drew Vallejo Posted at 2016-9-1 15:29
Your best route is to go on the FAA website and get all the training material from there. There ar ...
Thank you Drew, Could you point me the specific training materials from FAA please? I saw there are list of them, want to narrow to a few.
http://www.faa.gov/training_testing/
2016-9-2
12Next >
