Donnie
Flight distance : 3636782 ft
Was this right after an update ? did you have a recent crash ? Is it when it is close - 25 feet away or 1 mile away or always ?
Here are some suggestions :
Make sure you have the Image Transmission set to "auto " in the Settings . Make sure your RC antennas are straight up , Not crossed .
Make sure the Go App device ( Phone ) is not getting to Hot , be sure to try it when the system is cool and see if it goes away.
Turn off the "Record " feature on the Go app , most recording is done to the SD card anyway, and while there ge sure to clear the Video Cache .
Try another Go app device and see if it gets better, be sure you are using an approved device and the Go app is the most recent with the RC and AC.
Lower the Image settings , if in 4k , lower it to 1080 p. in the camera menu of go app, also check or replace the SD card.
Check the Camera settings option, make sure anti flicker is set to at least auto .
How does the video look on the SD card ? If it is also distorted we have a hardware problem - Need to know this for sure
I would start with these suggestions and see if it gets better, let me know
donnie
