Geebax
djiuser_BmwarrDz5BGg Posted at 11-30 19:47
I have the same question about my 4k. About the channel setting and all that. If it's not available for the 4ks, that sucks! Cause mostly the ONLY place I can fly, is at home. And my signal (under pressing the GPS tab) flicks good signal/interference. And I guess I have no way to change the channel?? When I close it to normal view, everything looks ok. Holds strong signal. And so far (at least 30 flights), there hasn't been any problems. But I'd just like to be able to change the channel if I can.
There is little to no point in manually changing the radio channel, even though it is actually possible in the settings. The aircraft uses frequency-hopping technology where it changes automatically to another channel if the one it is using sees too much interference or something or someone else is using that channel. The feature works quite well, and is best left alone to do its job. And BTW, the channel signal has nothing to do with GPS, you cannot choose GPS 'channels'.
