LB HDMI issue fixed
754 1 2016-8-31
hotcarp12
Flight distance : 4860725 ft
Hi,
I'm running LB2 with A3 and an A7 Z15. I was getting very poor video from the A7 after having used the same setup with a 5.8 transmitter for over a year.
Video was cutting out after the S800 had gone only 50-100m away, I thought it was transmission issue, possibly antennas on the LB.
Turns out that it was a poor connection with the HDMI connector going into the camera.  I had inserted the connector over the plastic camera plug cover for all this time and not had an issue but the HD feed requires a better connection.  Once I removed the plug cover from the camera and inserted the HDMI plug just a half mm more I had good connection and have had good video out to 700m away.
2016-8-31
DJI-Jamie
Flight distance : 112405 ft
Good to hear you were able to get yourself up and running.
2016-9-1
