mirekti
HaraldL Posted at 2017-10-8 06:46
A solution would be: a short (2 or 3 inches) flat cable with male (90 degrees) and female lightning connectors. I've been looking for that but couldn't find one.
I totally agree!!!
There is a right angle lightning cable, but only with the USB connector on the side.
At the moment, I am using a short 10" male to female cable which leads to the front fixed part above the handle so it doesn't put any extra work on the motors. I push the phone enough to cover the sensor, yet not to break the connector.
I am also using Moondog's anamorphic lens with counter weight, and it all seems to balance rather fine.
However, if there was an right angle male to female, either a connector or a cable, I would be able to push the phone a bit more to the right. |
