FUTABA + A2 Telemetry
3666 7 2016-9-5
pipeek
Poland
Hello everyone.
Is it possible to get telemetry from A2 displayed on Futaba T14 SG? I'm connecting to A2 unit via original Futaba reciever now.
If it is not possible could you point me to any solution that can transmit telemetry to ground? I'm using A2 flight controller and Connex transmiter for video.
Thank you for your time and help.
2016-9-5
Picture Factory
Flight distance : 5059882 ft
Yes, I have been using the Futaba T14 SG with the A2 and now A3 and I get my flight battery voltage and altimeter on my radio by using the optional Futaba telemetry cables that plug into the receiver. If you are looking for more detailed telemetry than that, then you have to move to the Lightbridge 2 system.
2016-9-5
timonroecg
Flight distance : 156401 ft
I'm using the iOSD Mark II.  It works pretty well and is an inexpensive solution.
You'll need to connect the A2 and your video output into the Mark II, then route the output of the Mark II into your vtx.  Depending on your cables/connectors you may have to do some soldering though.
2016-9-6
DJI-Jamie
Flight distance : 112405 ft
For timonroecg's suggestion, soldering will most likely be required, but the iOSD Mark II would come with the necessary cabling in order to solder most 3rd party VTX's.
2016-9-6
quality
Picture Factory Posted at 2016-9-5 06:57
Are you using the futaba SBS-01v sensor for the voltage? What sensor are you using for the altimeter? The Futaba manual just says you need a GPS sensor, wouldn't the gps that comes with the A2 be sufficient? I've been searching for details on how to get that working. Total Noob here...trying to figure this out. Thanks!
2017-1-17
quality
I would love to know how Picture Factory got this working...I've been fighting trying to get telemetry on the 14SG for weeks now with the A2 but it doesn't even seem possible without going with the iOSD. I had heard that "sometimes" the iOSD voltage display can be a bit "off" and so I wanted a voltage specific sensor tied directly to my TX.  I have a futaba SBS-01v sensor but have no idea where to plug it into the A2. Even if I did though, from my understanding the A2 only supports FASST modes "FASST-MULTI" and "FASST-7CH neither of which have telemetry enabled.
I'm pulling my hair out with this after having spent a bunch of money to get the SBS-01v sensor it doesn't even look like I can use it. The only way to make it works would seem to be having a futaba reciever on the drone specifically for telemetry.
2017-1-28
DRONE ACT
Flight distance : 52 ft
Does anyone have any new information ?
Regards.
2017-9-21
sck.dronebuddy
Flight distance : 197221 ft
Belgium
Coming back on this old tread...what are these "optional Futaba telemetry cables" and how do you connect them ??
2022-10-7
