Kamerar Baton Extender
2352 7 2016-9-5
setiawan3d
Flight distance : 7861 ft
Indonesia
In one side, this extender is looking nice rather than using a usual monopod and you can still have maximum control, but the other side, does the Osmo mount tough enough to handle the top weight?
http://kamerar.com/products/baton-extender-for-dji-osmo
https://www.amazon.com/Kamerar-B ... -Osmo/dp/B01JGZJK14
http://www.photographyandcinema. ... tender-for-dji-osmo
2016-9-5
uptowndisco
Flight distance : 7394987 ft
That comes with a side handle that attaches to the extension pole
so that you can hold to take the strain / weight away from the attachment
on the Osmo base  , I have this on order , I look forward to using it.
2016-9-6
jojoenglish85
definitely is dope, how much more battery power is eaten up when using this attachment?
2016-9-6
LenMiddx
"...In one side, this extender is looking nice rather than using a usual  monopod and you can still have maximum control, but the other side, does  the Osmo mount tough enough to handle the top weight?..."
The device is very light, weighing some 205 grams.
I haven't noticed any problems due to its weight.
The quality of manufacturing leaves a few things to be desired (the end caps don't stay on, and there is a thin rubber gasket under the contacts at one end that seems a little loose).
But -- it does give your subjects those extra viewpoints -- so it's worth having.
2016-9-7
LenMiddx
jojoenglish85 Posted at 2016-9-7 01:36
Without doing any detailed examinations or measurements, I'd say .......... none. All it's doing is passing electrical signals along 2 feet of extra cabling.
You may be losing a couple of seconds of battery use, but I couldn't detect it.
2016-9-7
LenMiddx
uptowndisco@hot Posted at 2016-9-7 01:27
so that you can hold to take the s ...
As you say, it comes with a side handle, but so far I haven't bothered to use it for the shots that I've wanted.
In the short time that I've had it, it's proved quite useful.
2016-9-7
DJI-Thor
Flight distance : 13602 ft
Quite an interesting design, makes me wonder if DJI should make something similar
2016-9-8
Matt-and-Riley
Flight distance : 324442 ft
DJI-Thor Posted at 2016-9-8 09:28
Yes, and can we have a motorised extension as well please. And how about a goose neck type connector instead of a rod. Look forward to it
2016-9-8
