P3S, new battery coming, do I need to update it?
colnemac
Hi,
Have ordered myself an extra battery, now I know that the advance and pro version you update the firmware on the battery, remote, and quadcopter seperately. Do I have to do anything with a new battery before using it, or will dji go tell me if anything needs doing to it before flight once I've plugged in and switched on?
Thank you.
2016-9-6
DJI Natalia
Flight distance : 318 ft
Hello Colnemac, you are correct, DJI GO APP will tell you whether it needs doing or not. Please check the status after you start it.
2016-9-6
helidan
Flight distance : 459951 ft
Should be able to use straight away, firmware updates are optional.
2016-9-6
colnemac
Thank you DJI Natalia and Helidan :-)
2016-9-6
DJI-Ken
Flight distance : 1515312 ft
colnemac Posted at 2016-9-7 04:58
And DJI recommends the aircraft being on the latest firmware but you are not required.
The battery updates, if there is one I would do and then you have to update the aircraft to get the battery update.
2016-9-6
colnemac
ok, currently up to date as only had it a month and updated it before i flew it.
2016-9-6
