MD_Icarus
That was a Litchi test mission up to the lighthouse, then manual after that.
I flew many shorter test flights before and that was just a test flight prior to my final flight, which I never flew after the Disconnect. I was planning to go around the lighthouse across the other beach there.
If you use Litchi, then I would suggest letting it complete. My initial concern was jamming, that is why I went closer and placed it in ATTI mode.
In this video, I lost complete connection at the 3.2 time mark, and this was a 12 minute litchi mission, which started at about 2.52 minutes and I never regained control! But I let litchi complete. I turned off Litchi and then back on the regain control, but the mission remained in the P4 memory, so it completed fine. So if you lose connection in Litchi, let it go. But when the signal was back at 100% and I still had Disconnected, I felt that I had to restart the app, which is scary, but it did not cause any issues. It actually completed the mission, without even having the mission on the app screen, once I re-started the app.
Ironically, I was about 0.8 miles in this one too!
