ricci2
Flight distance : 61158 ft
Hi All,
If you have been experiencing connection problems with the assistant2 I might have an answer.....I have had issues when connecting to the assistant 2 software where the M600 used to show up and now only the lightbridge 2 shows up on the software screen.
Turns out with some help from the Dji support team I found the problem, there is a usb port below the large flashing led at the rear of the craft where you access the A3, and LB2, this port and light connect directly to the LB2 and A3 via two cables and as the picture shows it has been installed with a very tight bend and when I wiggle the cable and connector the assistant 2 software works as it's designed. I would recommend people pop the top cover and check to see if the lower connecter on the A3 is like the picture and then do a mod to relieve the tight radius. I will now look over all the connectors after each flight now.
Thank you DJI support team for getting me in the right area to look.
r
bent cable cause probs
