droneflyers.com
Flight distance : 60709 ft
The 4K is cheaper for a reason!
The chances of having two bad batteries is VERY low......why is it that only new pilots seem to get them and those with experience don't??
Always condition your batteries - flying them no lower than 50% for the first 6 to 10 flights.
Use Deoxit Gold on the battery connections.
Make certain batteries are pushed in all the way.
The Standard and the 4K will have a range of up to about 2,000 feet - but depending on the antenna orientation and/or the area you are flying in it could be less. Only those who are going to use the machine for relatively close in (real estate, etc.) photography should get the Standard or the 4K. They are inexpensive and great for just fooling around but if range is an issue get a lightbridge model. |
