imagesbyjas
Flight distance : 286198 ft
All,
Just doing some routine maintenance by checking for cracks, motors clean, etc.. Went around the bottom of the body checking to see if any of the screws had loosened over time (primarily motor mount screws). What I did notice was the two screws (toward the center of the aircraft) right next to each of the 4 motor mount screws were all about a half turn or so loose. I don't recall them being that way, but am not 100% certain. I thnk these are some of what keep top and bottom of the body halves together. So, the question is should these be tight to stopping point (not overtightened or I'm sure it would be easy to strip the threads or crack something), or left about a half turn loose? My inclination would be that they should be tight to stopping point. Appreciate anyone checking theirs to see..
